question on welding on a doeser
  • question on welding on a doeser
    i got a custmer that has a doeser that has the two arms that come back from each side of the blade. and mounts to the center of the cat. on weld on nuckles he is going to replace the nuckles. i have been told two ways. what should i use rod or wire. this is T1- steel
    miller bobcat 250
    wc 115a
    spoolmatic 30a
    centery 250 mic
    2 lincoln 225 stick
    a 1954 hobart portable welder w/ willies jeep engine
    Both will work, however don't use hard wire. The welds won't stand up as well as stick or flux core. The knuckles are uaually cast steel of a good grade, preheat the T-1 to around 300F and allow to cool slowly. Most of the dozer blades I work on aren't T-1, so we normally just use a good quallity filler, 70,000 psi rod or flux core without preheating. .
    Jonny
    Dynasty 300DX
    Esab PCM 1000
      Most aren't T1. I do one at a time. Just wash the old ones off with a gouging tip , clean it up quick and throw the new ones in and start welding. The piece should be preheated from you washing the old one off. I use E71 M dual shield when I do em or stick if done in the field. Never had one break and they have some play in them so don't worry if they aren't 100% perfect. Sometimes the new ones have extra material which compensate if you just cut the tubing off instead of washing the old end out. Dave
        jonny and dave
        thanks for replying to my thread on welding on that dozer.i well take it in consideration. the guy has not call me back yet to let me know when he wants to do the job. thank you
        miller bobcat 250
        wc 115a
        spoolmatic 30a
        centery 250 mic
        2 lincoln 225 stick
          No problem.
          Jonny
          Dynasty 300DX
          Esab PCM 1000
