Miller 180 autoset vs Hobart Handler 190
  • Miller 180 autoset vs Hobart Handler 190
    Both are fine machines, that being said the Hobart doesn’t hold a candle compared to the Miller as far as build quality, I am confident the Hobart will die long before the Miller. As far as weld quality, the Miller can be set up to weld much crisper than the Hobart, the auto set feature will be greatly appreciated by the novice welder. I personally don’t like the “smooth start” feature and wish Miller would make it where you can turn this feature off. The Hobart does not have variable heat setting, again this will be fine for some and not for others, doesn’t bother me in the least. This is how I use my Hobart (http://www.millerwelds.com/resources...ew-shop-welder). I went to the Hobart to get away from the “smooth start” feature that I was fighting while attempting stitch welding on thin gauge material, here is the thread about that struggle (http://www.millerwelds.com/resources...istent-welding). In conclusion, even though the Hobart is doing a wonderful job for me and performing every task I ask of it………. I still wish it were BLUE. Does anyone sell Miller blue in a spray can?
    TB 302
    Sync 250 DX
    MM 180 Auto
    Lincoln tombstone
    DVI-2
    Why do we drive on a parkway and park on a driveway
    I am not seeing how the build quality of the Miller is so far superior to the Hobart.
    Minus the power pin, the gun is the same on both units. The spool hub, filter cap, and fan are the same. Minor differences on the wire drive, like the Hobart contains more aluminum, but they are very similar. The transformer and chokes are constructed the same way- not the same design obviously. The dimensions are different, as well as the look; however, the case construction for the most part is the same.
    The MM 175 that the MM 180 replaced was real finicky in the area of arc starts. If you didn't hold a tight stick out length the unit tended to produce some poppy arc starts. The Smooth start run-in seems to have been Miller's approach for fixing this issue.
    I like the MM 180; however, performance wise I feel the Handler 190 is the better unit, especially on the top end. On the top end the MM 180 arc becomes harsh and there is a fair amount of spatter. The Handler 190 top end arc is softer then the MM 180, the spatter level is significantly lighter, and weld puddle wet out is noticeably better.
      I would skip them both and go to the MILLER 211. It's 120/230 volt and more amps for little more money. If you get it tomorrow JUNE 30, the REBATE is still current.
      http://www.millerwelds.com/landing/build-with-blue/
        Danny, I agree with everything you said in the last paragraph. I only use the Hobart with small wire and low settings, however the guns are not the same. The Miller gun will not attach to the Hobart as I was told, besides the pin connection, the gun will not fit the drive. I was hoping I could use my 15' foot Miller gun on the Hobart but that's not happening. Miller does not recommend anything longer than a 12' and Hobart is at 10 even though I use a 15 in the miller all the time.
        TB 302
        Sync 250 DX
        MM 180 Auto
        Lincoln tombstone
        DVI-2
          BD1, I needed the small foot print welder to mount overhead in my small shop.
Name:	shop welder.jpg
          TB 302
          Sync 250 DX
          MM 180 Auto
          Lincoln tombstone
          DVI-2
            Does anyone really believe that is "bad" for a hobart handler, or millermatic to have a 15' mig gun????
            Is it really bad for the machine??
            I hear it voids the warranty too??
            Life is to short for cheap tools.
              Doesn't really matter if it is good or bad for the machine, Hobart's solution to keeping you from using a longer gun is to make theirs proprietary and not manufacturing a longer gun that will fit. I am getting along just fine with the ten footer on my overhead fixture, I can get to all parts of my table. But it sure would be nice to have a longer one..........I think my wife said something like that as well
              TB 302
              Sync 250 DX
              MM 180 Auto
              Lincoln tombstone
              DVI-2
                The question is will the drive system push the wire. I went from a 12' M-25 on my MM210 to a 15', and had to make serious adjustments to get reliable feeding.
                  My MM172 Challenger welds better than my MM251 and my MM180. The 172's case is made 10X better than the cheaper case on the MM180 and has to weigh at least 10 or more lbs more than the newer MM180.
                  My 251 always had sputtering problems on take off, most times it would sputter for a second them start off welding like it was supposed to but some times it would sputter and weld the wire to the tip..
                  I called Miller and talked them about it and they said to remove either a # 8 or # 79 wire from the machine's contactor (mine was a # 8 Wire, I painted it with yellow marker) removing the wire disconnects the machines hot start feature. Happy to report removing the wire fixed the sputtering and the wire getting welded to the tip problem.
                    Alan,
                    You're running .030 wire correct? Does your gun have the .030 -.035 liner in it?
                      The power pin is the end of the gun lead that inserts into the bore of the wire drive assembly.
