Shielding gas
  • Shielding gas
    I'm new to all this so here is a rookie question, how can I tell if the shielding gas is working. I own an original Miller Passport and I've just added an external argon/co2 tank. Thank you.
    If its not working properly or enough flow, you'll have bad porosity.
      If you can hear it comming out the nozzle it's working.
      Make sure the switch is flipped to the EXT tank.
      Those little welders never cease to amaze me.
      It's my go to welder for anything under 5/16''.
      Good Luck,
      Bob
      Millermatic 252 w/30A
      Big Blue Air Pak
      Ellis 3000 Band Saw
      8-RC
      Dynasty 200 DX
      XMT 350 MPa w/S-74 MPa Plus
      Millermatic 211
      Passport Plus
      Spectrum 625 X-TREME
      2-Lincoln SA-200 Red Face '68
      SA-200 Black Face '59
      SA-200 Green Lite '84
      SA-200 Green Lite '80
      SA-200 Red Face '69
      SA-200 Red Face '66
      SA-200 Green Lite '81
      '70 Black Face Round Barrel
        As bob just said, put the torch up near your ear and pull the trigger, you should hear the gas release in a hiss sorta.
          Or buy one of these. Kinda handy to have around.
          http://www.arc-zone.com/index.php?ma...8br0o4bd2ob6q1
            make sure ya flip the switch on the inside for the Passport to use the External tank
            I just noticed Bob already said that
            Ed Conley
            MM252
            MM211
            Passport Plus w/Spool Gun
            TA185
            Miller 125c Plasma 120v
            O/A set
            SO 2020 Bender
            You can call me Bacchus
              And be sure to open the tank valve, too.
                And make sure, you don't feed the wire into your ear. That might hurt.
                  Not if the ground clamp is attached to a bare toe.
                    All of the above and backseat tank valve. Open tank valve fully.
                      Not needed, all tank valves are required to fully seal at any point in their travel according to DOT. I calculated that it added days to my life by not spending the extra time turning them all the way on. A single turn seems to work just fine and hasn't ever caused any problems for me.
                        Shielding gas
                        Thank you to everyone who answered my question
