Syncrowave Coolant Pump
  • Syncrowave Coolant Pump
    My coolant pump on my Syncrowave 250dx (Tig runner) has failed. It doesn't turn on most of the time, and when it does, it is painfully loud.
    On the pump, it is labeled 'Procon CMP-7400'. All the online resources say that this pump isn't manufactured anymore. None are available on Ebay.
    In the manual, it is labeled as Miller PN 211045. A few online site have the pump in stock, but it is $450+!
    I see Miller changed up their integrated cooler. Is there an alternative motor/pump that won't cost 10% of what the whole welder cost?
    Still available from Miller, quite a pricey list though, $450 is pretty good in other words.
    What you can do is take it apart, and see if its simply gooey in there. Its the brass bushings that let go
      I've been told that Procon offers re-build kits for their pumps, but I never tried to get one. Before I spent $450 for a new pump I would certainly explore doing a re-build of the one that you have.
      Charley
      ______________________________
      Miller MM252
      Miller Bobcat 225NT
      Miller DialArc HF & DIY Cooler
      2 Miller Digital Elite and 3 Fixed Shade Helmets
      2 O/A torch sets
      DeWalt 18 volt 1/2" Driver/Drill
      DeWalt 18 volt 6 1/2" Metal Saw
      DeWalt Porta Band & SWAG Offroad V3 Table
      Milwaukee 8" Dry Cut Saw
      Milwaukee 14" Dry Cut Chop Saw / Delta Stand
      Milwaukee 9" Grinder
      2 Milwaukee 4 1/2" Grinders
      Milwaukee Hole Hawg 1/2" Drill
      Wallace 5 Ton Gantry
      Too many hand tools
        Edco distributing can probably rebuild your pump for you. Halsted and Hogan used to do it but uses Edco now.
        It comes back looking nearly brand new. http://www.edcodistributing.com/pcpumps.php
        Miller Dynasty700DX
        3 ea. Miller Dynasty350DX
        Miller Dynasty200DX
        ThermalArc 400 GTSW
        MillerMatic350P
        MillerMatic200 with spoolgun
        MKCobraMig260
        Lincoln SP-170T
        Linde UCC305 (sold 2011)
        Hypertherm 1250
        Hypertherm 800
        PlasmaCam CNC cutter
        Fadal Toolroom CNC Mill
        SiberHegner CNC Mill
        2 ea. Bridgeport
        LeBlond 15" Lathe
        Haberle 18" Cold Saw
        Doringer 14" Cold Saw
          Thanks for the info. I contacted them to see if they'll do it.
            They can't do it. I'll try procon for a kit.
              Might be barking up the wrong tree... but have you checked to see if you have a clogged intake strainer or a sheared shaft coupler and not a bad pump..??
              My Blue Stuff:
              Dynasty 350DX Tigrunner
              Millermatic 200
                If you do need a kit or Procon parts...
                I have heard good things about JC Beverage... the contact mentioned was Joe..
                http://jcbeverage.com/
                Hope this helps,,,
                My Blue Stuff:
                Millermatic 200
                  The shaft coupler is good.
                  There is no intake strainer.
                  I took the pump housing off and it spun up just fine. However, the vanes seem to be stuck in place. I suppose they need to move back and forth. I wonder if this is jamming the pump?
                    Cleaned up everything with a solvent. There was a sticky coating over everything. Lubed the vanes and Orings with vaseline and put it back together. Don't get the flowrate error, so it appears to be working fine!
                      COOL...
                      You are going to replace the coolant.with new.?? yes??
                      My Blue Stuff:
                      Millermatic 200
                        Didn't I say that on another thread, that is likely full of goo......
