what machine
  • what machine
    I was going to upgrade to a mm252, but was thinking of getting a multi-process machine. I have a extreme 12vs feeder, would a XMT 350 cc/cv be good. I don't have a tig or stick welder and was just figuring on getting an all in one machine. I usually just mig if I'm going to weld. I guess my question would be, would the XMT 350 with the 12vs or even a 22a feeder, replace the 252, that I would love to own.
    Thanks, Tom
    P.S. I'm only a hobby welder
    That's a step up in my opinion. It could be an even better mig set up if you sold the 12 vs in favor of a 12 rc. It would behave like an all in one mig, and not have a voltage sensing system.
      So you're saying that it would be an upgrade to the 252 and would perform like a stand alone mig with tig/stick options. What is your opinion of the Shopmate 300. Is there a durability problem with the circuit boards failing ?
      Thanks, Tom
        Yes, from what I've been told, and the research I've done. I personally have been considering an xmt with a RC12 for a while now to run as my fix setup. I have been doing a lot of site work lately since getting a new job, and my little 180 is really starting to be a hindrance in its output and duty cycle limitations. I just don't have the money right now. I to would really like some more opinions on the xmt with a rc feeder.
        As far as the shopmate, I have heard multiple times the mig arc is fantastic, almost second to none.
          I have a older XMT 304 ( 2002 ) Vintage with a S22 P-12 feed which is the same as a RC feeder which is a good set up, we just brought it back from a job where we had it down in a pit, it was nice because we could carry everything into the pit individually, re hook it up and weld, whether we needed to DC tig, Mig, mig aluminum. arc weld or air arc we could do all processes.
          Not to mention we can run 230v single phase, 230 3 phase or 460 3phase.
          On this job we had to hook it up 460 3phase.
          I cant speak for the shop master but the XMT is a very diverse machine with a high quality arc.
          You can also install a optima controller to do pulse mig ( I have never tried the pulse however.)
          On the other hand, I doubt if you buy the xmt that you will say the xmt is way better than the 252, is it a little better Probably, just don't expect it to be leaps and bounds better.
          I would say the XMT will have more sweet spots than the 252.
          Kind of like I have a miller matic vintage, it has a sweet spot all the way up to #5 setting where as #6 kinda sucks and then we swith it to High and the sweet spot comes back at what would be #8 on up.
            Nothing wrong with a VS model just no remote hook up for amp adjustments (must adjust amperage at the machine). I am currently selling a 350 VS on Ebay Less than 3 years old. I have 2 more just don't use it enough to keep it sitting around.
            Price is currently at $600
            2- XMT's 350 cc/cv
            1- Blue star 185
            1- BOBCAT 250
            1- TRAILBLAZER 302
            1- MILLER DVI
            1- PASSPORT PLUS
            1- DYNASTY 200 DX
            1- MAXSTAR 150 STL
            1- HF-251 BOX
            1- S-74d
            1- S-75DXA
            2- 12-RC SUITCASES
            1- 8-VS SUITCASE
            2- 30 A SPOOLGUNS
              I have a new 252 where I teach at, and I just hate the thing on hard wire.... Now I put DW-50 dual shield wire in it and it's much better machine.
              Now I have had XMT304 and 350 and they are far better then the 252/250 machines, but then again the 2 machines are in different classes.
              Just my $.02
              Railmen
              2007 Trailblazer 302G
              2004 Invision 354MP
              1999 60 series feeder
              2005 Maxstar 200DX
              2007 CST280
              1999 HF 251-1
              older Hobart hefty wire feeder
              Hyperthrem 600
              Maxstar 150S(such a cute welder)
              had and sold........
              2003 XMT 304CC/CV
              1947 Lincoln SA200G short hood
              1963 Lincoln SA200G
              1975 Lincoln SA200G(best machine ever had )
              1970's Lincoln SAE400G
              2 Maxstar's 200DX's
              1 Maxstar 200SD
              CST 280
              2 CST 250
              MM130
              Railmen
                Thanks for the response. I think the Shopmate or 350 is the way I'll go. Is one more reliable than the other ?
                  Miller would have to weigh in as far as reliability of those two. I would suspect the Shopmate 300 has a edge for two reasons. It would never really get bumped around like the portable machine would, and is a less complex design. Has a excellent mig arc, and different then any Miller transformer or inverter I have used from them. Call it a excellent balance in arc quality. Here is the way I look at it...One of the very best Short-arc machines Miller has ever made.. 251-252 machines are not even in the same ball part in arc quality.. (IMO) I could live with the Miller inverter machines pretty well in the short-arc, but prefer other brands of inverters for their short-arc type. (Thermal-arc MST 400 for one) To me it welds very similar to a Esab 260/300 (Which I owned a few) It's a great stick machine, and has a excellent tig arc, but lift-arc only..and needs a tig torch with a gas valve..
                  I remember when the Shopmate 300 DX first came out the Miller rep said the guys at the lab plugged in a pulse box for a Dimension 450NT ,and had the Shopmate pulse.. I don't even see a pulse box for one at this site, so just something I have heard done.. Take it with a grain of salt, but interesting anyway..
                    Railman, I'm surprised your saying that, On the other hand I have not run the new 252 but I have the XMT set up, a 1987 MM200 and approximately 1996 Miller Vintage 250 amp machine.
                    Neither me or the 2 guys that work for me have ever expressed that there is a big difference between the 3, If I had to choose one as being the best I would go with the XMT but once again not leaps and bounds better in our opinion.
                    We have started using the Lincoln 71 elite dual shield in the XMT.
                    As far as reliability for the shop mig machines, They just keep working year after year without a problem.
                      I was in the LWS and was pricing out the Shopmate and 350. I'm not sure which one, but sounds like I can't go wrong either way.
                        I just find that most of those stand alone MIG's just never seem to have enough power for my hot hand....... Now I have never run a 350P.
                        Guess I'm just pushing them too much....
                        Railmen
                        2004 Invision 354MP
                        2005 Maxstar 200DX
                        2007 CST280
                        1999 HF 251-1
                        Hyperthrem 600
                        2003 XMT 304CC/CV
                        1963 Lincoln SA200G
                        2 Maxstar's 200DX's
                        1 Maxstar 200SD
                        CST 280
                        2 CST 250
                        MM130
                        Railmen
                          Railmen
                          If you get a chance...
                          Try the MM350P....
                          Bet it makes you smile....
                          My Blue Stuff:
                          Dynasty 350DX Tigrunner
                          Millermatic 200
                            I'm gonna put my .02¢ worth in. I replaced my MM 252 with XMT 350 and S74dx feeder. It is leaps and bounds ahead. The 252 is a toy compared to the XMT.
                            Syncrowave 350lx
                            XMT 350 CC/CV
                            S74DX Feeder
                            30a spoolgun
                            Hypertherm 1000 g3
                            Harris O/A
                            Cincinnati lathe
                            Acer Ultima "Bridgeport Mill"
                            340hp Quincy and 400 gallon of air
                            Other doodads and a stoker coal stove
                              Apparently I don't weld on big stuff like a lot of you, The largest stuff that I ever get are excavator booms, sticks, and the buckets, sometimes we do some loader buckets also.
                              So its very rare for me to weld anything more than about 1-1/4" other than the shanks that hold the teeth.
                              My little 250 amp migs like the 252 do a great job on that.
                              If any of you find the MM200s or the 250s not being big enough try using lincolns dual shield 71 Elite with .045 wire and 75/25 gas, It will give you additional heat over the hard wire alone.
