New syncrowave 210 weld critque
  • New syncrowave 210 weld critque
    Picked up a syncrowave 210 and figured i would give tig a go to see how it worked. Got a couple of pics. Just looking for some suggestions to get my skills up. All welds are lap joints on 1/8" aluminum @ 130amps with 4043. 2% ceriated 3/32" tungsten. Thanks
    Welcome to the forum rday78.
      Overall they look pretty decent. It seems you may be having a bit of a hard time keeping steady. Make sure you are very comfortable, relaxed, and make sure the entire length of the bead stays comfortable for you to reach. I do mock runs of a bead so I can make sure the torch cable doesn't get bound on something mid weld, or me filler rod hits something. Just keep practicing at it, looks like your on the right teach.
        Thanks... im a bit shaky by nature but ill keep at it. On the fillet welds i have a hard time directing the arc straight into the joint... it bounces from vertical plate to horizontal. Guess a bit more practice is in order
          Really good start
          All you need is learn to brace/steady your torch hand
          more practice and to develop your rythm...
          you may laugh but a metronome to give you a regular time spacing for your dabs of filler in the puddle may help you to get that going...
          I know... sounds goofy but that even beat may help
          Dab & Move Dab & Move.....
          there are free metronome downloads on the net that you can play on a notebook as you practice...
          http://www.webmetronome.com/
          after a while it will become second nature...
          on bracing that hand... things like the "Tigfinger" are becoming popular..
          http://www.weldingtipsandtricks.com/...tigfinger.html
          but there are lots of bracing methods.. do what works for you..
            getting close
            you seem to be on the right track. .I notices that you had a lap joint and you burnt the top edge off. try not to do that and keep the tig torch slightly towards that bottom plate. heat will naturally reflect up towards the top plates,so favor the bottom a little. grip the tig torch close to the top and try keeping it about 5 to 10 degrees, pointed in the direction you going.
            as others have said practice.
            you will be ok.
              Thanks for the help... need to get my bottle refilled then get back to practicing
