Trailblazer 302
  • Trailblazer 302
    Do the GAS powered 301 and 302 trailblazers have enough juice to run, I hate to say it on the Miller forumn, but a LN-25 ? Or will I be kicking myself down the road if I by one. Money is kinda tight right now so I cant really afford a diesel atm. Any recomndations or advise would be appreciated
    WORK HARDER.....MILLIONS ON WELFARE DEPEND ON YOU!!!!
    Of course, now you HAVE to set your engine to 62.5 hz probes in the 120 vac receptacle terminals. On a Kohler the adjusting nuts are on the right side of the back of the engine near the exhast with a couple of 3/8" gland nuts. On an onan, the adjuster is above the right side valve cover. you have to loosen off a 10mm nut and adjust a 8mm/ 5/16 lock nut and tighten a adjuster bolt.
      I have a ln 25 and a vs 8 and they both run wire ok my 302tb. The vs8 or vs12 will be more compatible to the miller machine.
        Ln 25 will run fine...I do it all the time
          Ok, Bless me FATHER for I have sinned .
            Yep, works great on my TB251.
