Help please
  • Help please
    Welder: Miller Auto Set 180
    Gas: 75/25
    No flux on wire
    setting is 0.35 wire thickness for 3/16 steel tube.
    My experience welding, not a lot.
    When I am welding flat surfaces I weld a nice bead (atleast ok).
    When I weld a 90 degree corner I cant get the dimes to stack. What am I doing wrong. Each time the weld is bunch up in the center
    I have adjusted the gas pressure, feed rate and temp. But the corners all look bunched up in the middle.
    Well coyotebgone as this is your first post welcome to the forum.
    Lincoln A/C 225
    Everlast PA200
      Check out this site, info on how to achieve stack of dimes. Also do an advanced search on this forum with the title "stack of dimes".
      http://www.profabricationtechniques....g/mig-welding/
      Good luck, Ja
      sigpic
      Dynasty 200 DX
      Millermatic 350P
      30A Spoolgun
      Lincoln Pro Mig 140
      Hypertherm Powermax 30
      14" Rage Evolution dry saw
      40 ton press brake
      Evenheat Heat treat oven
      1x42 / 4x48 belt grinder
        Post up some pictures to better help you.
        Miller Bobcat 225NT onan
        Millermatic 211
        Spoolmate 100
        Miller 130xp
        2. 4-1/2" grinders
        1. 9" grinder
        14" Makita chop saw
        1/2" Aircat impact gun 900#
          it looks cold to me, but no being a 75/25 user, by choice, i will wait for guys with more hood time with that mix to give their enlighted opinion.
          Are you pushing or pulling ?
            Welcome. Drop down to .030 wire i think you will like it better...Bob
            Bob Wright
              Yea I only use .030 and .023 in my 180. Your picture looks like you may be running cold, or too much wire. And possibly moving too quickly, which is probably a reasult of one of the first two.
                The roughness of the weld bead along the toes (edges) of the weld is generally an indication of to high of a wire speed setting for the voltage.
                  Gas: 75/25
                  No flux on wire
                  With the Miller 180 you should be using .30 wire. If you are not changing settings before you round the corner, good. You are probably moving too fast. That would explain the flat welds on the sides, and the humped up weld on the top. If you are changing the settings-Don't!!! Set your machine based on the thickness of the material and your welding speed. Maintain a consistant puddle.
                    Looks like you tried welding the "bulging" weld vertical up? If so you need to watch a video or two on welding vertical up mig and then practice doing a bunch of them. I also wouldn't bother trying to get the "stack of dimes" look to your weld as you are welding with mig not tig. Just run straight welds without whipping, the only time you should be manipulating the weld puddle is if you are weaving.
                    and wp2025 weldcraft torch
                    Miller 125c plasma cutter
