Cast Iron Tub
  • Cast Iron Tub
    Got an email today asking,
    I have a cast iron tub that the legs don't attach as firmly to the tub as I would like. Is there any way to tack these to the tub without harming the inside finish on the tub? Or maybe add a cross support to the legs not attached to the tub?
    Anybody weld on something like this where the finish has to be preserved on the other side? I don't know what the finish is. Seems kind of risky to me.
    There is another cast iron tube a guy wants the feet welded back onto that broke off while moving it. So any tub experience knowledge would be helpful.
    I would expect the vitreous (porcelain ) enamel to spall off or otherwise suffer damage.
    Miller stuff:
    Dialarc 250 (1974)
    Syncrowave 250 (1992)
    Spot welder (Dayton badged)
      I would expect the same thing. Maybe you could make a steel frame with steel legs in the same foot print as the original to support the tub and attach(tack on) the original legs to preserve the "Look". The steel legs would be hidden by the originals, but be supporting the weight.
        I would expect damage to the inside. Even if you got it to hold without damage I would make it clear that there is no warranty of any kind.
        Maybe remove the legs & make a decorative cradle for it to sit in/on?
        MM250
        RCCS-14
          In your case it sounds like epoxy might be the right move since they're just a little loose.
            Weld them right on no problem, just need a little JB weld
            and wp2025 weldcraft torch
            Miller 125c plasma cutter
              Certainly some good ideas and options here.
              Was the JB weld for real? I have a story about JB.
              The boat in my avatar has thru hull exhaust and regular exhaust. Captains Call was what it was termed then. When diverted down thu the outdrive it travels down an aluminum Y pipe that comes together just before going thru the transom.
              There are steel flappers midway on each side. Mercruiser has a design flaw where these flappers can come loose and fall down to the bottom of the Y and wear a hole in the Y pipe inside the boat. This will sink it if your auto bilge pump don't work.
              Requires engine to be pulled out to fix the pipe. However, I used a very long screwdriver and a mirror to scrape away the paint from the worn thru hole, and pulled the flapper out from outside the boat with homemade long nose vice grips.
              Then took a long 1/4" ID clear hose, taped to a long steel rod. Mixed the JB weld and sucked it up into the hose. Held it there until I could get it on the cleaned hole with the aid of an extended mirror and light.
              Then blew back thru the hose to deposit the JB weld where needed. I guess that's been over 7 years ago and it happened twice from both flappers. Still holding well today with no leaks.
              So, I listen to fixes people made with JB weld. I used to think of it as a joke but that stuff can be a magical cure for lots of things.
              Camping,,, the running Bunk boards came loose on the trailer. While the empty trailer was at the campsite I got some new lag bolts but the wood was stripped out. Filled the holes with JB, put in the new lag bolts, 10 years ago. Still holding fine.
              Just one more note, when some of your bolts come out and you try to load your boat on the trailer, the boards float up and make it impossible. Take a thin plastic grocery bag to tie down the board and pull you boat right on it.
              Oh crap, got off topic, its late you guys know how I ramble at this hour.
              Thanks again for the ideas, I'll be talking with him next week about it.
                Similar suggestion as I made, just using the original legs as part of the decorative part, just not structural to the frame. At least with this option, you don't have to be concerned about whether the porcelain will pop off or not. Just make sure to put a good rust proof coating on it before final install.
                  Hardrock,
                  This may help you.
                  Nick
                  http://ohmegasalvage.blogspot.com/20...-tub-foot.html
                    Fusor and other structural adhesives have been crash tested and many automobile parts are assembled using them.
                    http://www.lord.com/products-and-sol...sh-testing.xml
                      I have a cast iron tub that the legs don't attach as firmly to the tub as I would like. Is there any way to tack these to the tub without harming the inside finish on the tub? Or maybe add a cross support to the legs not attached to the tub? ...
                      Over a couple of decades ago we had a 100 year old house with a clawfoot tub. Since I was renovating the bathroom, which included a new tile floor, I had to disconnect the tub at which time I decided to chrome plate the feet. I got the tub up on a dolly so I could move it about. Then I soaked the set screws and dovetail joints with WD-40. The feet came off without much trouble. When I put it back together I merely snugged up the set screws which are meant only to prevent the feet from sliding out. The feet may have rocked a bit when the tub was suspended. The truth is, I don't quite recall. Regardless, it is the dovetail joint that is taking the stress, which is what you want. Furthermore, I would think that the old the dovetail joint castings are designed to be loose. Certainly better than too tight Sooooo, I would just snug up the set screws and not worry about looseness of the dovetail joints. After it is leveled, the weight of the tub will remove the looseness
                      Working on the plumbing, the knob and tube wiring, and the tender plaster wood lath walls reinforced with horse hair was an education!
