Connect a Spoolmatic 1C to a Maxtron 450
  • Connect a Spoolmatic 1C to a Maxtron 450
    I didn't do my homework and purchased a Spoolmatic 1C without a WC1 controller. I thought that it would just be a matter of hooking the gun to my 14 pin connector and run it off of panel. I contacted a miller weld tech about hook up and was told that I needed a WC1 controller. I asked if the spool gun could be ran off of my 60m controller. The tech didn't know if using a 60 M would work. The Spoolmatic that I purchased is in great shape but, I am not sure where to go from here. Purchase a WC1, pursue a way to hook the spool gun to my 60M, or cut my lose and sell the spool gun. Does anyone know if a 60m can work with this gun, or have a good WC1 for sell. Thanks in advance for your help.
    A definite no on the Spoolmatic-1 running off the 60M wire feeder. The SM-1 was designed for direct connection to the early generations of the Millermatic 200 that provides the proper power and contains the required circuits to operate the spoolgun. The WC-1 weld controller simply provided those things mentioned above so the SM-1 could be used with non-MM200 CV power sources.
    IMO, your best option is to pick up a WC-24 controller and Spoolmatic 30A which is a perfect mate to your Maxtron 450.
    That being said, I know a gentleman that's looking for a SM-1 to go with his MM200 and another that's selling a WC-24 and 30A (both of which are NOT me) if you're interested. If you are, PM me an email address.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    http://www.millerwelds.com/images/sm...rolleyes.png?2
      I would be interested in selling the spoolmatic.
      [QUOTE=duaneb55;314835]A definite no on the Spoolmatic-1 running off the 60M wire feeder. The SM-1 was designed for direct connection to the early generations of the Millermatic 200 that provides the proper power and contains the required circuits to operate the spoolgun. The WC-1 weld controller simply provided those things mentioned above so the SM-1 could be used with non-MM200 CV power sources.
      Last edited by 3dcycle.blogspot; 12-07-2013, 10:12 AM. Reason: Info on email so my email on post was removed
        I just bought the spool gun on eBay. I am just over $400 in on this gun including shipping. Thanks in advance for your help
        As I look at used prices I am not sure that I can afford a WC-24 and 30A but I would be interested in knowing what the asking price would be. Thanks
        Last edited by 3dcycle.blogspot; 12-09-2013, 03:39 PM. Reason: Removed email address
