Popping
  • Popping
    When using my mig welder it seems to let the wire out ok until I start to weld. But when I start to weld it starts to pop all over the place and pushes the tip up and down and burns holes all in the metal I have the wire speed and amps set right but it still will not weld right. Can someone please tell me how I can get it to let wire out smoothly when welding. I have even tried to replace the liner in the hose and I am using the right polarity.
    Slow your wire speed down it can't burn fast as its coming out or that's what has happened to me . I'm talking about the wire hitting the metal and kind of pushing back up it bumpy.
      Machine?
      Settings?
      Solid wire or Fluxcore?
      Ed Conley
      MM252
      MM211
      Passport Plus w/Spool Gun
      TA185
      Miller 125c Plasma 120v
      O/A set
      SO 2020 Bender
      You can call me Bacchus
        Popping
        Check your wire spool. I had the same issue a while back and it was the way the wire was wound on the spool. It was looped around in such a way that it was tightening the wire on the spool. So it would weld fine for a while the spit and sputter.
          Popping
          Ck ground, make sure good clean contact also ck ground clamp make sure it has good clean wire to clamp connection & not loose.
          This can also cause same type problem.
            It sounds like you would have done this already, but check the tip. Make sure your spool tension is not too tight, and make sure the drive roller tension is tight enough. If your welding flux core, are you using knurled drive rolls?
              what brand and model are you using
