please help what to buy
  • please help what to buy
    I am helping out a friends shop weld good size aluminum boxes and am welding with my dynasty 350 right now but it's way way way to slow and owner said they were wire welding them with spool gun or push pull set up Most the plate aluminum is 3/8 to 7/16 and they have been tacking on 1 in blocks to all four corners on these parts So my question is what set up would work for me ? I don't wanna spend the farm but would like to get a wire set up for this any advise would be great thanks in advance
    Also I might be able to get a power source as well if that would help out
      Sounds like a perfect job for a Millermatic 350P with the Alumapro Push-Pull gun..
      http://www.millerwelds.com/products/...p?model=M00151
      http://www.youtube.com/watch?v=_qU-0XqmAo0
      I have one and it is the cat's meow for MIG.. between the MM350P for MIG and the Dynasty 350DX on TIG... you can pretty much handle whatever comes along....
      Just my 2 cents worth.. But I own both.. and you could not trade me out of either one...
      My Blue Stuff:
      Dynasty 350DX Tigrunner
      Millermatic 200
        Add Content
          Anything on the cheaper side of that ?
            For my money.. nothing comes close...
            you might find it more cost effective in the long run to buy the more capable machine from the beginning and be able to handle the larger stuff at longer duty cycle... rather than being limited by a smaller machine..with a lesser duty cycle.
            Doing those aluminum boxes continuiously at decent speed and not needing to stop and let the machine cool between beads..will require some horsepower..
            My Blue Stuff:
            Millermatic 200
              What kinda amps would I need to weld that thickness ? What about a spool gun ? Thanks
                Amperage is a function of Voltage X Wire Speed for a given size wire..
                See figure 6.9 page 32.
                Not so much Amps available... but the duty cycle at the given amperage..
                See figure 4.2 page 11
                this is the amount of time that you can weld at that output before you have to stop and let the welder cool
                http://www.millerwelds.com/om/o1327ah_mil.pdf
                The 30A spoolgun is a well made piece of equipment and heavy duty... but it is tiring to sling all that weight around all day and the frequent spool changes...
                Great for smaller jobs..
                one feature that the MM350P has that most others do not.. is the ability to pulse... this gives a pretty bead that looks a lot like TIG and reduces the total heat input to the work..
                My Blue Stuff:
                Millermatic 200
                  Will I don't do very much of this and prob won't after this but this might go on for a few months but just can't drop 5 g on a unit to weld these things worst comes to worst I will have to keep tigin it but its taking to long I was thinking a millermattic 200 with a spool gun but not sure if that would work or not
                    Oh and pretty don't matter they *** machined after all welds are done these are for sand molds and go to a foundery
                      The MM200 with a 30A would be a good inexpensive short term solution..
                      the MM200 is a lot more machine than the name would suggest...
                      it is 200 amps at 60% duty cycle and 270 amps at 35% duty cycle..
                      they can be found on the used market for between $400-600 w/o spoolgun..
                      My Blue Stuff:
                      Millermatic 200
                        Don't know what kind of budget you have, but this is a good option
                        http://www.millerwelds.com/products/...p?model=M00218
                        Look at cyberweld or your local welding supplier. You can find the machine for about $2300.00
                        JIM
                        Millermatic 350P Aluma Pro
                        Maxstar 150 STL
                        Trailblazer 302
                        Suitecase 12RC
                        Extreme 12VS
                        Extreme 8VS
                        Spoolmatic 30A
                        Miller HF251D-1
                        Passport Plus
                        Spoolmate 100
                        Hypertherm Powermax 45 and 85
                        Dake 75 ton H-Frame Press
                        JD Squared Model 32 Bender
                        Miller Digital Elite
                          The MM252 is a decent machine... it has output and duty cycle nearly identical to the MM200...60% Duty cycle @ 200 amps.. will drive a 30A spoolmatic and it does have gun on demand which is convenient..
                          figure 4.2 page 12
                          http://www.millerwelds.com/om/o230693l_mil.pdf
                          My Blue Stuff:
                          Millermatic 200
                            figure 4.2 page 12
                            I have had both. The 350P and now the 252. I like the 4 roll drive on the 350P, but for the price, the 252 is a good machine. And as you stated, the 15A or 30A is an option and the gun I prefer over all the others.
                            JIM
                            Maxstar 150 STL
                            Trailblazer 302
                            Suitecase 12RC
                            Extreme 12VS
                            Extreme 8VS
                            Spoolmatic 30A
                            Miller HF251D-1
                            Passport Plus
                            Spoolmate 100
                              Just to clarify don't mix up the older MM200 & the new multimatic 200, which can also be called a MM200. Two completely different units.
                              I run a MM250 with a 30a spool gun on the heavier aluminum I do. It works fine. I'm in a situation like you where I don't use it much but when I do it gets used for a day or two all day. This set up, a MM200/250/251/252 with a 30a is what I would recommend. If you buy it used you can always recoup your cost when done by reselling it.
                              Not knocking the 350p but if it's going to sit for long periods in the corner it doesn't make good business sense.
                              MM250
                              RCCS-14
