weld coupons
  • weld coupons
    Hey guys I've been a student for a year now. Thought I'd put up some work on coupons I've been doing at home. Just bought a multimatic 200 love it so far on tig. The first is 3G aluminum 18g, and the second is a 3G steel.
    Real nice work. I think the pict descriptions are reversed. Steel is first. Keep up the good work.
    HH 210MVP
    Spoolrunner 100
    Powercraft AC buzz box
    Lotas LTP5000D plasma
    Victor Oxy/Acet
    30 ton press
    A few brand name tools
    Lots of no name tools
    A wife to worry me
    and 4 dogs to supervise me
      What did you weld the aluminum with?
        weld coupons
        Multimatic 200 doesn't weld aluminum
          Sure looks like it does to me...
          Just For Home Projects.
            Yea but it doesn't, that's why I asked what he used...
              weld coupons
              Can't you get the spoolgun for the Multimatic???
                Yes you can. But his aluminum coupon is tigged, which is what we're talking about.
                  weld coupons
                  I was just sayin I thought one can weld aluminum with the Multimatic using a spoolgun.
                  In no way did I imply that his weld was done WITH said spoolgun for multi. Obvious that the weld was done with a tig.
                  Hopefully he is just confused with which machine he used.
                    I see. Not trying to be rude, sorry if it came across that way.
                      weld coupons
                      It's ok my man. I was just clarifying myself. No worries.
                      I thought the same when I saw the pics and the caption. For a sec I felt really bad about my spoolgun mig skills till I was like, NAAAAAAAH that's tig
                        It DOES TIG so I guess then it would do Alum...? Are you sure you are talking about the correct machine?
                        He has the MULTI-Matic not the Miller-Matic.
                        I am sure I saw a "contractor kit" that IS a TIG set-up.
                        "Just bought a multimatic 200 love it so far on tig." From OP
                          I Am sure it does not tig ALUMINUM. It's a dc only power source which can tig, mig and stick in DC. It can hook a spool mate up to it for aluminum, but as I and others have pointed out that coupon is clearly tig welded. Are you sure your talking about the same machine?
                            I won't claim to know much about tig or this machine but it can be set up to do DC tig but not AC tig. From what I've read aluminum is AC tig only. Likely preferably with HF as well. If I had the machine, the setup and the gas I'd probably try it just to see what it would or wouldn't do. But I can be contrary.---Meltedmetal
                              That is why I put the question mark in there too...looks like he was claiming it could be done. I don't do it, and by it I mean TIG of any kind.
