First time spool gun user! Help
  • First time spool gun user! Help
    Hi guys, I have a millermatic 185
    and a friend gave me a used 30a spool gun!
    I'm not much of a steel welder but been wanting to learn aluminum.
    now the issue when trying to use it I can get a weld that looks ok for the first time
    but every other try starts with a spark and wire balled up in the gun?
    I can't tell that I am doing anything different?
    but it is most of the time. The wire speed is controlled on the machine not the gun
    because of the type machine. Any idea what to look for? Thanks
    Huh, you can't plug a 30a gun onto a 185 for one thing, maybe tells us what machine you really have?
      It does look like you can not add a spool gun to the mm185. You can the mm180 though
        The hookup chart mentions a "Spoolmate 185"
        http://www.millerwelds.com/products/...gun-chart.html
        Might have to do some adapting to make that 30A hook up...
          Guys, Sorry. I bought a switch kit and a adapter cable that lets me hook up with a switch inside Anyway it won't use the spool gun wire feed control
          but have to just use the machine wire control
            "switch kit and a adapter cable"
            Could you give us more details, supplier?, model?
            installation and op instructions?
            pics?
              My MM185 has the adapter switch and has hose tee on it. Power cable just bolts on inside the machine. It is supposed to use the 3035 gun not the 30A.
                Pretty tough to hookup the 30A to the 185, even so, 030 AL wire and straight Argon is what your after
                  Really. I have been using my MM185 with a 3035/Spool Mate 185 since '99...Bob
                    Sorry I did not complete my thoughts, I was thinking that it was not a plug and play.
                    My mm211 is set up for it from the start. I did not see anything about it in the manual for the mm185 I found at a friends shop.
                      I'm certainly no expert but somebody told me this when I was in your position so I'll pass it on to you. Aluminum absolutely must be clean to get a proper weld. If it's oxidized it must be cleaned before welding. You can get the right kind of acid from your welding supplier. Make sure that the aluminum alloy your welding on is the same alloy that your welding with. Your supplier should be able to help you with that also. Use a stainless steel wire brush to clean your weld after each and every pass. Make sure it is a stainless steel brush and never use that brush on anything other than aluminum.
                      To address the problem of the wire burning back and balling up. I think either your wire speed is too slow or your heat is too high. If that's not the problem then make sure your tip is recessed at least a minimum of ⅛" inside your nozzle and when you pull the trigger make sure that you can hear the gas coming out just before you see the wire coming out. I hope something mentioned here will help. Good Luck!
                        As JL- mentioned Aloominum welding is a lot more finicky than steel.
                        everything has to be just right and even then you will have some tough starts to get the feel of AL mig welding.
                        The Tip to work distance has to be precise, wire speed precise etc etc.
                        Clip the wire for every start.
