grind wheel for tungsten
  • grind wheel for tungsten
    guys,
    what type of grind wheel makeup should i order to sharpen my tungsten on a standard bench grinder that takes a 6" wheel with a 1" shaft hole ?
    curious what you guys are using.
    at work we use a belt sander, but everyone uses it for all kinds of different things and im afraid its contaminating our tungsten when we use it.
    we have a grinder that nobody uses and want a dedicated wheel for it. the current wheel we have, not sure what its made of, its green in color, wears out really quick, not hard enough.
    thanks guys..
    Syncrowave® 200
    Lincoln AC/DC 225/125
    Lincoln Weld Pak 100 wire feed
    Try a search. It's been hashed out 10,000 times.
      That soft green wheel is probably for grinding carbide tooling.---Meltedmetal
        I have found the best thing for me is a flap wheel on a 4 1/2'' grinder. Nothing fancy
          This was posted on the Weldingweb site. I didn't search for the thread on this but I did buy this harbor freight circular saw diamond wheel. It works great. I mount it to the side of a existing grinding wheel on a bench grinder. Thing is great for $ 10.00. Use a 20 % off and save more.
          http://www.harborfreight.com/replace...ner-98862.html
          http://weldingweb.com/index.php
            thanks everyone.. i just picked up one of these diamond wheels and hope to make a mount for my grinder tomorrow....
            Syncrowave® 200
              No need to make a mount just take the handle off your grinder and put it in a vise upside down, dont squash it go easy and your done.
                The harbor freight wheel is rated at 6600 RPM'S MAX. I would ''ONLY USE IT ON A BENCH GRINDER '' not on a angle grinder unless it is variable speed or less than 6600 RPM'S.
                  I use a 1/4 collet angle grinder with 100 grit 3" roloc disks for past 3 years. Works great and cheap.
