Opinions Appreciated
  • Opinions Appreciated
    Below is a link to a lathe that I found. Any information concerning capabilities,condition and price would be greatly appreciated. This would be my first lathe and a huge learning process. I do understand that the tooling is usually a much graeter cost that the lathe itself.
    http://littlerock.craigslist.org/tls/3918612357.html
    Thanks for any advice,
    Nick
    I hope you are on your way to get it. You should be posting "What do you think of my new lathe". Looks like a screaming deal to me.
      Originally posted by walker View Post
      i hope you are on your way to get it. You should be posting "what do you think of my new lathe". Looks like a screaming deal to me.
      +1..!!!! Grab it!!!!!...
      My Blue Stuff:
      Dynasty 350DX Tigrunner
      Millermatic 200
        Not much center-to-center distance on that old gal, but well worth what is being charged. Probably would handle 75% of what you would be wanting a lathe for and as long as you were considering it as a first lathe it should be well worth it and have your cash outlay easily recovered down the line. Belt drive will keep you from dodging shrapnel on a crash...
        Miller DialArc 250
        Lincoln PrecisionTig 275
        Hypertherm 900 plasma cutter
        Jet 14 X 40 lathe...ditto
        Logan 7" shaper
        Ellis 3000 band saw
        Lots of dust bunnies
          Did anyone see a compound in the photo because I did not? If there is not one with the lathe are they costly and readily available?
          Thanks,
          Nick
            I think you can see it in the 6th picture down or so. The tool holder that is in it is the lantern style, but is sitting right on the dovetail. It should have a semi spherical washer and wedge set up to adjust the tool holder, or better yet, just pick up a QC tool post
              Thanks,
              Nick
              I don't see a compound rest there. Best to ask the seller if it is a concern. They are nice but there is lots of machining you can do without it. From looking at the pictures I would say that you would have to change the cross slide to incorporate a compound rest otherwise the tooling may be too high to work properly. A compound rest gives you the angles but they are often less robust than the heavy-duty cross slide I see here. That means they may flex under heavy service when the straight cross slide may not. You could always get a milling attachment and build them(shorter cross slide and compound). Might be a fun learning experience and it still looks like a deal to me.---Meltedmetal
                Just a quick update on the lathe. I wanted to thank everyone for their input. On Monday evening I took a look at it and got cold feet. The lathe was in pieces and under his house in a makeshift shop. I asked him how he got it in there and he said he placed it on a piece of plywood made a hole in it and drug it with a come along. The more I looked at it and the more I considered the information you gave me (lack of compound) I decided against it.
                  Where ya' located Kiwi?
                  Miller DialArc 250
                  Logan 7" shaper
                  Ellis 3000 band saw
                    Hey Roy,
                    I am located in Arkansas.
                    Nick
                      Nick,
                      Arkansas sounds only slightly better than Wyoming for used lathes. 'Bout time to take a summer vacation to get away from the heat...maybe a trip up to the Great Lakes or East Coast and watch Craigslist ads along the way?
                      Miller DialArc 250
                      Logan 7" shaper
                      Ellis 3000 band saw
                        That type of LeBlond lathe didn't come with a compound. It is a rapid production type which was made for mass machining of parts that were all the same like brake drums for example. I looked at a newer version a few years ago but passed for the lack of a compound. My buddy here in NE Ohio has 3 South Bend heavy 10's if anyone is interested...Bob
                        Bob Wright
                          Nick,
                          Roy,
                          I could not agree more. It is very hard to find nice used equipment in my state. I guess because it is an agricultural state and not a state that was centered around manufacturing.
                          Nick
                            Bob,
                            Thanks for the information, I am now glad that I backed out. I will PM you about the SB lathes.
                            Nick
