Need to make steel rings
  • Need to make steel rings
    Hi would this machine be able to bend a 25 mm/ 1 inch bar into a 360? If anyone has and recommendations I'd appreciate. I don't have any heat (propane). I'm trying to avoid renting.
    With that bender you may have to make the rings in halves and weld them together...Good luck
      1" steel bar, no heat, and that radius? I think you are in trouble.
      CG
        No it won't. That is a tubing bender & you are asking about bar. Big difference.
          Could it be done with heat and that bender? I've been on to a gas supplier and now you can buy the propane canister/cylinder. So I will have heat.
            Bayweld I never even though of welding the two halls together, genius!!
              No
              Round Tube Capacity 7/8"
              Wall Thickness .047"
              Square Tube Capacity 1"
                Burn em from 1" steel plate and do a round over to suit...Bob
                  How many do you need to make?
                  this might work for you
                  http://www.westechrigging.com/riggin...are-rings.html
                    You can heat bar stock in a forge and bend them around a piece of tube with no problems. Forge is easy to make.
                      I would either sub it or burn them from plate
                        Question to the op.
                        How many do you need to make/buy? What exactly is the use?
                          You can buy those.... http://www.liftingsafety.co.uk/produ...ings-2424.html
                            @turbo they're a bit pricy at 21
                              @mmw initially 10 for Highland games, but if I get the bending right I've railing to make up so plenty of bending to be doing 180's though not 360's bends.
