Problems with Pipepro 350
  • Problems with Pipepro 350
    When welding during the day When it gets warmer about 90, The machine turns over but does not start up It takes two or three times before it starts up . Does anyone have any ideas what it could be ! Please help !!!
    Maybe the carb's main jet needs to be opened up....it's set to lean.....
      Where would one find the carb on a diesel? Is it that it's hard to start when it's warm outside or when the engine and ambient temperature are warm?
        As I recall the carb is right next to the distributor
          The Pipepro 350 is diesel, With a Mitsubishi engine, So I'm clear sorry about that !
          It's doing it when the engine is already hot And using it during the day .
          You guys any idea I'm stumped !
            Engine controller is damaged, Take it into your local Miller repair shop and have them change it out.
              Gentleman diesels are injected there is no carb and no distributor.
                Q
                Sure there is. Just to the left of the aerial bearing and just above the drongle retroflector! (I'm sure that post was meant as humour as was this one!)
                Tim
                Many cordless tools...........
                2 cordless hammers
                2 cordless punches
                1 cordless chisel
                2 cordless screwdrivers, 1 + and 1 -
                and a cordless adjustable wrench that also doubles as a hammer.....
                  Cruizer is this a on going problem with the Pipepro , have you heard of anyone else with the same problem ?
                  Thanks for the input !!
                    A friend of mine had the same problem and fix. Works great.
                    Do you adjust the carb with a metric crescent wrench also. Lol
                    Millermatic 210
                    dialarc 250
                    spectrum 375x
                    trailblazer 302
                    Lincoln 135
                      Yes quite common, and for the idiot non diesel guys its best to lean out and rejet the carb, and change out the spark plugs
                        Only one guy not guys. I'm well aware this is no carb hence why I asked where one would find it
                          Hey Cruizer where is that engine controller at I don't see it in the manual and is it expensive ?
                          Thanks for the input I appreciate it!
                            Left side under the blue sheet metal and pretty much dead center in the white box.
                            Your machine would have to be still under warranty, sooooo, free.
                              Hey Cruizer called and talked to a miller tec he said there was a bad batch of them .
                              He's putting one in the mail for me be here in two days !
                              Again thank you !
