Suitcase Extreme 12 vs
  • Suitcase Extreme 12 vs
    What are all the power sources that will run the suitcase welder? Thanks, Tom
    Check out the manual.
    http://www.millerwelds.com/om/o257950d_mil.pdf
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
      I weld with mine hooked up to 225 bobcat,302 TB and 300 classic.Not all at the same of course. Works fine on heavy equipment repairs. I guess it would work on Miller thunderbolt as long as it puts out enough voltage for the drive motors to run and burn the wire.
        If you do a search, you'll see hat they operate best on machines with CV output.
        CC output machines will work with really heavy stuff and flux core apparently.
        The feeder can't adjust the feed rate fast enough on CC to mimic true CV short circuit mig.
          I had the same question. I came upon a suitcase that was being discarded (insane thought). Does anyone know if and how well it will work with the Dynasty 200 DX?
