student welder needs help
  • student welder needs help
    Any tips or techniques on overhead 4f n 4g smaw process
    They truly are both very easy my guess is 7018 and the real key is keeping a tight arc length. It is exactly like welding in the flat don't over think it biggest mistake students make ..... Good luck!!
      Keep as tight arc as you can with 7018. Put on leather so you aren't worried about burning yourself and just focus on the weld
        Keep your arc tight and your rod straight up no angle at least that's what I just learned at school just graduated so good luck
