14 pin receptacle 250 Syncro
  • 14 pin receptacle 250 Syncro
    Serial # KC320772
    Connection K is supposed to be ground. It is on the other machines (KG234929 etc).
    My concern is that K has no metal pin receptacle- therefore no ground.
    Diagram (o353h_mil KC 320772 page 31) shows:
    Pins A,B.C and E grounded.
    Pin D goes somewhere- is it grounded?
    Pin K is not connected.
    My 14 pin remote will be returned this week.
    Do I ignore the missing K on this machine, plug it & go?
    Thanks, the archives have been very helpful but find anything, anywhere for this issue.
    Mike
    Pins A, B, C, D & E are not grounded. Those are capacitors (C-16 thru 19) connected to them and ground.
    No, your machine doesn't use the K pin (chassis ground) nor the G pin (circuit common/neutral) that when used are typically common to each other so ignore them and when you get your remote back, plug it in and get welding.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    http://www.millerwelds.com/images/sm...rolleyes.png?2
      Thanks for your reply
      The detail-
      And the definitive 'ignore/get welding'
      Mike
