Calling meltedmetal and Cgotto6
  • tackit
    started a topic Calling meltedmetal and Cgotto6
    The weather is finally warm and the son dropped off his drill Sunday so I going to do the welding table job this weekend. I have a question on tightening the red heads.... how many turns do you go, they say up to five turns, is that what you guys do?
  • tackit
    Today I got the angle iron brackets cut and drilled, picked up the 3/8 SDS Plus drill from the SIL and got my camera, I'm spending time reading up on it so I can take some pictures... hopefully tomorrow I'll be drilling the holes.
  • Cgotto6
    I reuse them from time to time. If it is still grabbing I would dare say its stupid to toss it. Them things don't grow on trees!!
  • Precision
    Question for ya. I've got this dude from Ireland I work with( incredible builder) and he swears up and down you can't reuse a tapcon. Now in a industrial or new building job I would NEVER do that but I have used some rather large sized ones(10 1/2 inch) over again on my buddies home retaining wall. I pulled em out of a cinder block wall that held in cooler panels for a beer cooler in a restaurant. Have a bunch still and the threads look good but he says I'm "daft" for tryin to use em. Just someone else's opinion that uses them a lot. Be easy on me!lol
  • Cgotto6
    I agree, slam guns usually do more damage than help. Love tapcons and redheads, use them almost everyday.
  • Precision
    Your most welcome Tackit!
  • Precision
    Concrete actually takes many years to"fully"dry as it sucks moisture up from the ground. That's why you have to vapor barrier if you put hardwood floor or something like that on top of concrete. "Green" is within 24-48 hrs to 5 days. Depends if you add accelerants to it for a faster cure. We mainly use a fiberglass reinforced crete at 6" with rebar and wire reinforcements. A lot of guys like the .22 Hilti's and duo fasts that shoot the fastener into the floor. I myself do not. It only takes a min orso extra and if the shot doesn't hold you end up using a tapcon or red head anyway so why not use em from the start. "If it ain't broke".
  • Cgotto6
    Green to me is within a month or so, but you can really do anything with it within 3-5 days. A year is more than adequate time for anything.
  • clint738
    Originally posted by Precision View Post
    Only two problems we have are putting them in when the Crete is still green or use the wrong size bit.
    I've been reading this thread from time to time since I have to install some anchors for something.
    What is your definition of when the concrete is still green? Like days old, weeks, months, a few years?
    The shop building I bought has a slab about a year old and it already has a LONG crack running down the middle. It only has a 3 1/2" slab probably. Guess that is the quality of work people do around here though. I would be blazing hot at the company who poured it if they had poured it for me.
  • tackit
    We build pre-fab metal buildings and have been using redheads/hilti's/duo-fast anchors for the last 4-5 years. We used to lay out all the anchor bolts before the concrete and install them while the Crete was curing. Now it's just drill and go. Only two problems we have are putting them in when the Crete is still green or use the wrong size bit. Actually just used some yesterday attaching a deck to a concrete pad. Works like a charm. Hope all goes well with your installation.
    Very nice of you to wish me good luck Precision, thanks
  • Precision
  • tackit
    Originally posted by Cgotto6 View Post
    Are you going to use anchors in addition to those? Or is it stable enough now?
    Mr. C I'm going to put an anchor on each leg opposite the crane. If that isn't enough then I'll put two on the crane side. The table only came up about 6" lifting the generator on the table so I'm thinking two on the far side will be enough. The generator and the Snapper's deck will be about the heaviest things I lift on the table.
  • Cgotto6
  • tackit
    The picture shows how I used the crack joint to slip some 3/8 plates down into to the concrete 2 1/2" to keep the table from moving when cranking on something in the vise. The plates held the weight of the generator but the opposite side of the table lifted up about six inches.
    Table with the crane
  • Cgotto6
    Nocheapgas, that's already been discussed in his previous thread, wedge anchor is his best bet.
