miller mig power cord extension
  • miller mig power cord extension
    the guy i bought my mig welder from gave me an extension cord he made up. it is super heavy duty and about 50 ft long....problem is, it is still as can be... I have seen quality power cords that are totally limp. i imagine its the stranding on the copper wiring....
    I searched for power cord extension online...but it isnt obvious if the feature of limpness that i am looking for is in the cord....
    what is the type of cord i am looking for and how is it described...even better does anyone know where to buy one? single phase 240 volt 50 amps( millermatic 250.
    I can use the one I have, but id rather get a more controlable cord
    bob
    I have one built out of 8/3 soow cord. Fairly flexible. I wonder if yours is made from romex ? That is not suitable for the application of extension cord!
      Most people make their own up. If you want a 50ft cord then 8/3 so cord will be fine.. you will have trouble finding one already made up.. and if you do then it will be really expensive. Try your local electrical supplier
        Just get raw wire from your local hardware store and put what ends match your receptacle and plug on welder. Sounds like maybe someone made your current cord out of solid wire and not stranded. Like Elvis said, this is not a good idea.
          I use 6/3 SO or SJ cable(stuff that extension cords are made of),add the ends you want from Menards,Lowes or Home Depot.
          I have never seen a cord like this for sale commercially.
            Slight correction- he needs CORD not wire.
            Wire goes in the wall to feed a receptacle.
            Cord is what you want for a power cord or an extension cord.
            The price of cord is not cheap and the connectors are not exactly cheap either.
            $123.00 for a pre-made Cord 50' cord
            http://www.brweldingsupplies.com/wel...y-duty-8-3-50/
            Build yer own:
            $39.00 bux for connector set
            8/3 cord runs around $1.75-2.00/ft
            50'x 1.75 = $87.50 + $39.00 = $126.00
              this is a great place to buy a ready made cord, the cost difference is moot. It calls for an 8,,,, this is at rated output,,, I use a 10 on occasion becaue I am small short circuit only but if you intend to wring the guts out of it in spray 8 is the right wire, works great for buzzers. Only reason not to use it is weight or because you already own something else and the demand is light.
                its acyually a pretty rare day i have to use a cord for a welder, i will move or add outlet if there is much chance it will be a regular event. I had outlet 20 ft from hoist and i got a cord but it was well worth it adding another recept, same wire, not used same time and same breaker ratings.
                Even though a compact can run on 50 I put 30 in at their "home" outlets, figure it cant hurt to close the gap a bit for free.
                  Broccoli is correct its called cord. My fault.
                    Build yer own:
                    What is a connector set? You just need a receptacle and a plug. They wire goes into them and under screws. This post is going complicated... for such a simple thing as a cord. Lowes carrys cord up to 10/3 at least the one by me does. And no one there will guide him like they should. That's why I said he needs to go to a electrical supplier.. they will set him up.
                      This is 10/3 with a 4 prong plug and 3 prong rec. The box is typically called a 4in handy box with raised cover.
                        dat is a connector set- just terminology. They're called connectors when they are on a cord.
                        http://www.brweldingsupplies.com/mal...ers-plugs-set/
                        Receptacle goes in the wall or on the wall/surface mount.
                        No one said go to Lowes. I was just pointing out that the cost of a pre made 8/3 cord is about the same price as building yer own.
                        What are you paying in DE for 8/3 cord from the Electrical supply shop?
                          Receptacle is what's on my cord... in the pic above.
                            And yeah.. I would buy a pre made if it was the same or cheaper to get. 10/3 cord is about 2 bucks a foot. So I dunno what 8/3 is... definetly more.
                              Power Grip Heavy-Duty 50A Extension Cord - 30 ft.
                              (2 Reviews) Add A Review
                              Catalog Item # 37814
                              This Item is In-Stock and Ready to Ship
                              Internet SALE
                              $127.49 SAVE $42.50
                              http://www.campingworld.com/shopping...d-30-ft-/37814
                              When you disconnect always grab the plug so your fingers don't get behind it and touch the long stabs. I see this one has a handle to prevent contact with the stabs.
