just bought a MIG welder....question on gas
  • just bought a MIG welder....question on gas
    I finally bit the bullet and bought a welder for my home, for doing projects on my boats. I bought a Miller 250 with a 30A spool gun. i also got a 50 ft extension cord...the cart has a place for 2 bottles of gas. the guy said one is for pure argon and the other is for argon -co2 mix( for welding steel). OK ill have to rent the bottles. DO i really need the mixed gas bottle? the reason i ask, is that i have a TIG machine at work and we use ultra pure Argon on that machine.. and i weld aluminum, stainless steel and regular steel with the same gas....seems to be fine.
    gan i use the pure argon at home with my MIG machine to weld steel ( knowing I have to revert the regular wire feed in the machine)
    thanks
    PS the mig welded way way easier than i had heard...we did test welds before i bought it, and we used just aluminum sitting on the shelf..didnt wire brush it or nothing...welded fine9 to my eyes.... I was welding in 5 minutes...of course my welds are a little high......but the finess is like learning to use a clutch in a standard car.....
    bob
    you can use pure argon for mig welding steel and stainless. The only difference is the mix is cheaper. If you are mig welding aluminum, you are going to need pure argon anyways. Keep an eye out on Craigslist for owners tanks. They should be about $80-$100 bucks. Renting them gets expensive if you aren't doing production work and they are just sitting in your garage.
      Lift the cover on the spool side of the machine. The chart will tell you which gas to use.
      Miller Dynasty700DX
      3 ea. Miller Dynasty350DX
      Miller Dynasty200DX
      ThermalArc 400 GTSW
      MillerMatic350P
      MillerMatic200 with spoolgun
      MKCobraMig260
      Lincoln SP-170T
      Linde UCC305 (sold 2011)
      Hypertherm 1250
      Hypertherm 800
      PlasmaCam CNC cutter
      Fadal Toolroom CNC Mill
      SiberHegner CNC Mill
      2 ea. Bridgeport
      LeBlond 15" Lathe
      Haberle 18" Cold Saw
      Doringer 14" Cold Saw
        You can't mig steel with pure argon. You can run co2 or some blend of argon co2. The most commonly used is a 75/25 mix, or also referred to as c25. When migging aluminum with the spool gun you must run pure argon. Using straight co2 will result in a little more spatter than with c25. Stainless requires a tri mix it stainless mix. Obviously you can run flux core with no gas as well, but will have different characteristics. Then there is dual shield and many other blends for different configurations...
          Do not use pure argon for steel & stainless mig.
          Aluminum mig = pure argon
          steel mig = argon/co2 mix or straight co2
          Stainless mig = trimix
          MM250
          RCCS-14
            There is a good explaination of the why's and the wherefore's in Praxair's Shielding Gas Selection Manual. Should be available at the Praxair website.-Meltedmetal
              I will have to second both MMW and Meltedmetal.
              You DO NOT want to use 100% argon to MIG anything steel.
              JIM
              Millermatic 350P Aluma Pro
              Maxstar 150 STL
              Trailblazer 302
              Suitecase 12RC
              Extreme 12VS
              Extreme 8VS
              Spoolmatic 30A
              Miller HF251D-1
              Passport Plus
              Spoolmate 100
              Hypertherm Powermax 45 and 85
              Dake 75 ton H-Frame Press
              JD Squared Model 32 Bender
              Miller Digital Elite
                pure argon doesn't offer the penetration 75/25 blend does on steel, bead shape and depth along with arc characteristics are effected with different gas mixtures.
                  There is tri mix for steel,argon,CO2 with a touch of oxygen and then there is tri mix for stainless which is helium,argon and a touch of CO2.
                    Alright... goofed that one. I haven't used my mig in a while and forgot about using pure argon while mig welding steel and stainless.
