Clear Coat - Mild Steel
  • Clear Coat - Mild Steel
    Have a little art project for class made of mild steel and mig'd. I'd like to coat it in something if possible that will prevent it from rusting and keep the shine after I polish it.
    Is there something I can get from a place like Lowes and spray on it that will do this?
    Miller 211 MVP
    Hobart StickMate LX 235
    Lincoln AC 225
    CutMaster 42
    A hot dip galvinizing layer will prevent most atmospheric corrosion. You may need to look around but it shoud be in the hardware store. This will create a neat design in the piece though. Good luck.
    Jobe
      clear coat
      I would use the old yellow label ppg clear it works great for what you are describing. It's a acrilic type of clear coat you don't see it much anymore
      ARMOR
      MOBILE WELDING&SERVICES
      Trailblazer 302
      X-TREME 12VS
      Spoolmatic 30A
      Millermatic 135
      WeldCraft WPseries TIG torch
      Smith oxy set.
        Few here
        http://www.sculptnouveau.com/Results.cfm?category=7
        Another one called Permalac http://www.permalac.com/technicalfacts.asp
          spray can of laquer
            clear
            Go to the local home improvement store and get a spray can of polyurethane or lacquer.
            JIM
            Millermatic 350P Aluma Pro
            Maxstar 150 STL
            Trailblazer 302
            Suitecase 12RC
            Extreme 12VS
            Extreme 8VS
            Spoolmatic 30A
            Miller HF251D-1
            Passport Plus
            Spoolmate 100
            Hypertherm Powermax 45 and 85
            Dake 75 ton H-Frame Press
            JD Squared Model 32 Bender
            Miller Digital Elite
              Krylon Clear gloss or Clear satin works great. Just make sure all water and oil is off steel (wipe down with acetone). Spray lite coats 20 - 30 minutes apart. Make sure you get all the cracks and clevis's are covered.
              Good luck.
                Deft
                  You folks are awesome. Thanks.
                  Miller 211 MVP
                  Lincoln AC 225
                  CutMaster 42
                    Just so you are aware, spray can clear coats are great, and dry fast, but are a little fragile, so handle with care or it will scratch off. Also nee to wipe down with thinner before spraying o it will stick.
                    Perma-Lac, and Clear Guard from Sculpt nouveau and better by far, and are available in a spray can, more expensive, and you have to wait for the brown truck to bring them
                      Permalac
                      Sculptors seem to recommend Permalac, so I bought some. Have not used it much yet. I understand Nikolas also has good clear.
                      Krylon Clear also seems to work OK. Just be sure to get the glossy.
                      Run a test piece before you coat your real work.
                      It is all in the prep, so sand/polish until you are happy, then put on clean new rubber gloves without a powder coat, and use solvent to clean any oils. I spray immediately after I use the solvent, (allowing time for any residual solvent to evaporate).
                      Richard
                      Syncrowave 200, Millermatic 211, Victor torch, Propane forge....
