Dynasty settings
  • Dynasty settings
    looking for a good set up on 3/16 steel like the pulse n stuff like that any help?
    You should not need pulse for material that thick. Especially if you have a 200dx. Pulse will compromise the heat input too much for plate like that.
      so keep everthing to stock settings
        Sure. Simple DC works very well.
          What do I adj if I want a thinner bead width
            Grind a different geometry on your tungsten, and or bleed helium into your argon flow.
            Pulse on the other hand tends to flare the arc IMO, however that is just my observation and could be BS.
              turn up frequency
                Mayor
                Originally posted by jarred.chance View Post
                turn up frequency
                Unfortunatly, Adjusting output frequency will have no effect in DC, only AC. High pulse settings up above 150 pulses per second can help narrow up and focuse the arc off the end of the tungsten resulting in a narrow weld bead. High pulse rates will also produce a nice ripple effect in the bead.
