Millermatic 200 wire feed problems 2
  • Millermatic 200 wire feed problems 2
    Hey Cruizer, can you offer any advice here?
    Having some wire feed problems with my mm-200
    mm-200
    serial jf958985
    using the circuit diagram b-093 009-a
    i only have a single circuit breaker inside the wire compartment and a single fuse on the front panel
    reviewed the mm wire feed threads, found the thyer thread most useful
    but, need something more than is there
    this had some previous work done at a shop before i got the unit, a few splices, it worked fine for a while, but now symptoms below
    pull the trigger, will strike an arc, gas comes on, cr1 works, cr2 does not work, can weld, but wire is intermittent
    both sr1 and sr2 are ok, main contactor working
    cr2 does not work, but, has 36 volts to it
    changed cr2, still not working
    no power to wire motor
    i have occasionally been able to get wire feed to work but the cr2 relay does not move when that happens
    not sure about the cb1, it seems popped out and does not seem to want to reset, but, has continuity between 2 adjacent pairs of posts
    would like to make sure the wiring on cr2 is correct, but, not sure how to read the diagram ... which wire numbers go to which pole on the relay?
    any thoughts out there?
    Cruizer can you offer any help here?
