Love my Millermatic 35S but...
  • started a topic Love my Millermatic 35S but...
    Is there any way to get more wirespeed out of it? Seems like I have it cranked on only the second or third power setting and that's it.....it makes some killer welds but high voltage is out of the question I guess because I can't feed more wire....
  • tedster
    Originally posted by turbo38t View Post
    I have it cranked at 100 with .035 and c25.....seems like it's running slow....I can easily get ahead of myself....it welds beautiful but slow...
    that MM 35 is only a 150 amp welder try running 0.30 wire i had a Hobart Handler 187 it welded liked a dream with 0.30 wire on it, it did not like 0.35 wire
  • Guest's Avatar
    Guest replied
    He's referring to TIG MIG haha.....who even does that?
    Originally posted by Cgotto6 View Post
    How can this be used with mig then?
  • Cgotto6
  • aametalmaster
    I haven't heard of deglazed 7018 wire, what is it? You sparked my curiosity.
    I think he is talking about a 7018 rod with the coating ground off with a wire wheel...Bob
  • Cgotto6
  • Millright52
    Yes bob may be correct. My hobart e-z 125 flux core runs .030 much smoother, you are the adjustment for.035.just takes patience. And sometimes for really thin weird composition alloy tubing, I even feed in some deglazed 7018 rod as a consumable to beef up the puddle and reduce the heat. Sometimes you just have to toy around with it. Dave
  • aametalmaster
    I agree with bob. My mm180 doesn't even like .035. I always use .030 with good results.
    My MM185 doesn't like .035 either and the specs for the 185 and 35 are about equal...Bob
  • Cgotto6
  • aametalmaster
    Put some .030 wire in it and you will see a big difference...Bob
  • walker
    Does the motor get hot? If so you may need to pull the transmission apart and regrease.
  • concreteguy
    The wire speed is controlled by the voltage tap. The higher the volts, the faster the wire speed. The wire speed on that is the fine adjustment
  • Guest's Avatar
    Guest replied
    Is it possible that the wire speed is semi relative to the voltage on this old machine? It has the plug in voltage selection(not a knob).....I haven't tried it on anything more than the 3rd voltage setting and it felt like with the wire speed maxed out it was "almost" enough.....is this adjustable?
  • Guest's Avatar
    Guest replied
  • aametalmaster
    I have had quite a few 35's and don't remember wire feed being an issue...Bob
