Angle Grinder Guards
  • Angle Grinder Guards
    First thing I did was remove my guard, several years later, a week ago my loose flannel shirt was caught by a wire wheel. Good thing for me it had a second layer liner in it but still ripped that shirt to threads in about a second. I was lucky, no blood.
    I put it back on.
    A guard protects much more than shirts, you can direct the sparks as the guard will pivot around. Helped today as I was working pretty much pinned under a trailer about a foot off the ground. Could only use one hand at any time.
    The guard was a life saver. Controlling sparks was a blessing. Using it as a guide for the one handed cleaning was great also. Keeping the wheel off the wood in those stressed and stretched positions would have been impossible without the guard.
    Took me a few years and a near accident to realize what I have been missing. I will never remove another guard.
    And I will never work laying in gravel, underneath anything so low you stay stuck 50% of the time. I hurt from head to toe.
    I took one off a 9" grinder when i was a kid in the shop and still have the extra large scar in my left wrist where the wheel hogged out the skin and i too have been caught by a wire wheel...Bob
      I carry several pcs. of old carpet with me. About 2 ft. x 4 ft. They help a lot when being on the ground. I use them for kneeling as well.
      When you have days like you had that's when I question why I am doing what I do. Not sure I want to do this in another 10 years? But if I do I will be more selective of the work.
        I wear a leather apron from harbor freight. It saved a lot of shirts.Those wires are a pain to pullout.
          Always pays to wear safety glasses and a face shield when you run a grinder too. Even with a face shield once I had a wire get up under the face shield and stick below my safety glasses. I still can't figure out how it found it's way there but it sure did. And wearing ear protection is a good idea too.
            I did the same thing removing the guard on a 4 1/2" grinder I got from my parents working in the welding shop when I was 14.
            Now I just keep the guards on the grinder since I have more to lose with a son to raise. Would only take one cutoff wheel or grinding disk coming apart to wish you had the guard on. I have nothing to prove and working without the guard on the grinder and with no ear protection doesn't prove I'm tougher to anyone.
            One thing I do credit my father with always pushing was to NEVER work a grinder with your shirt tail not tucked in. Thanks to that advice I've never had too bad of an experience with a grinder, but he did tell me of a case where someone had their shirt tail get caught up in a big grinder (7 or 9") and it opened their chest cavity up pretty good.
            I now opt for a full face shield in addition to safety glasses when running a wire brush. I've gotten hit too many times in the cheek with flying wires to try it without the shield anymore.
              Well, I guess I'll look into some scrap carpet. I would imagine there is plenty that would just melt from a spark and not catch fire, kind of like the back of my head does.
              I questioned the work too and told sweetthang last night it was time to start back exercising again. I feel like a square that's been rolled down a hill.
              Speaking of those wires, a person could make some kind of weapon out of those things. I've pulled them out of my forehead so they had to hit bone, LOL,,, it would probably be better to use them on a weed eater far from your body.
              The last one got stuck on the grinder, the part holding the wires would turn when I tried to remove it and not the threaded area. A quick tack fixed that.
                I use a piece of 24" wide rubberized conveyor belt. It is about 1/2" thick so gravel stones become a hump instead of a knob. Kind of heavy but effective and you have to be really dedicated to set it on fire.
                As for grinders.....guards on always and even with safety glasses and a face shield I get stuff in my eyes.
                Meltedmetal
                Other ideas-tractor/trailer mud flap or cut up a cow mat
                  good ideas for sure.
                  I'll be picking up something.
                    You guys scared the **** of me - I have 4 or 5 grinders ALL without the guards. I have never had a problem but maybe my luck is running out....I will try a couple to see if I can still use the grinders...................
                    I keep one just for the wire wheel and another for hard disks, I will try those. The others with lap disks are hard to use with guards.
                      Your just an accident waiting on a time to happen, and the clock is ticking.
                        I carry a extra 41/2 and 9" grinder with the guard removed. I only use them with a flap disk. I have also seen people take about a half inch off the bottom of the guard so you can still lay the wheel flat on a surface and
                          I haven't used it much but it's one tool I should have bought right from the beginning to reach those tight spots a wheeled grinder can't get at.. no struggling, no wrangling around to find a way to clean up that last bit in a corner or between close objects that stop wheeled grinders from reaching.
                          Where the weld was ground off the tank is actually near where a 1" tube fed air into the tank from the 2" water trap, it was cut out and the holes repaired in both the tank and the trap.
                          The damage to the weld was caused by first trying to get at the patch work with a 4 1/2" and then my 7" grinder with a new wheel to get more reach. I said enough of this nonsense and ordered the Dynabraid.
                            Took all the guards off my grinders. Got bit several times. Put all the guards back on. That darn grinder/wire wheel just took a lot of skin off my right index finger...hurts like ****. I guess it's a part of the game, and will have to be as safe as possible.
                              It is a rare occasion that I take them off anymore. I have had to to get it into a tight spot, but I don't like it. With the guard on you can also set the grinder down face first, and keep the spinning wheel from throwing debris at you while it winds down.
