Having trouble welding galvanized to rusty pipe
  • Having trouble welding galvanized to rusty pipe
    hey everyone! i'm new to this forum and i was having trouble and heard of this site on a tv show. My problem is I have rusty pipe and a galvanized cattle panel and i'm making a cattle pen out of it. I am having trouble with the vertical part. everything else goes in awesome but I am doing something wrong on the vertical part. the pipe thickness is schedule 10 so its easy to burn through which is my main problem. The welder i have is a bobcat 250. Thanks in advance for any opions. I'll post pictures tommorow so it will make more sense. Wondering what rod you would use and what amperage i would set it on?
    Use 3/32 6011 on DC+ at around 50 amps, adjust the amps up or down as needed. Start at the bottom and go uphill with a whipping motion. It will also help a lot if you grind the galvanized off and clean off some of the rust too
      You can also try it on dc-, some people prefer it over DC+ because it burns more crisp (kind of similar to 6010) . I use dc- with 6011 when I have a lot of gaps to fill
        I like 3/32 or 1/8 6010 DC . Actually, I thought that 6011 was the same as 6010 but for AC.
        Check out the MILLER weld calculator.
        http://www.millerwelds.com/resources...calculator.php
          6011 is either or. Its more of a do it yourselfer kinda rod. A lot cheaper than 6010
            Unless I'm doing a root on pipe I always prefer 6011. and I agree with Weldon welding 3/32
            Galvanize is a coating as well as rust so clean it up, gope the pipe to minimize the gap.
            You also may want to use a method where you weld for a second, let it cool a second and restrike the arc and keep doing this untill your gap gets closer.
            You might also want to do a weave then stop for 5 seconds and let it cool then do another while you stack them on one another forming a wide weld bead.
            Good luck.
              As long as it wasn't a structural weld when I had gaps to big to fill I would cut or find a piece of steel that would fill the gap and weld over it, making it part of the weld.
              Or run the sides down hand jumping from side to side so the weld would cool on one side as we welded the other. we called it spiderwebbing.
                thanks everyone for the help! only question i have left is on my machine for the amps it just has one through 10. What does 50 mean? how do i figure it out? Am i missing something on the machine? below is what my machine looks like. thanks again!
                  On the right- that is for Fine control adjustments after you select the amperage range .
                  http://www.millerwelds.com/om/o249336b_mil.pdf
                  Ed Conley
                  MM252
                  MM211
                  Passport Plus w/Spool Gun
                  TA185
                  Miller 125c Plasma 120v
                  O/A set
                  SO 2020 Bender
                  You can call me Bacchus
                    Set the middle/ or course adjustment to 40/100 amps and use the 1-10 to get to the 50 amps or whatever you decide up to 100 amps.
                    Looks like each line represents 10 amps on the 1-10 scale in the 40/100 amp course range scale. So the knob set on 5 = 50 amps ...set on 10 = 100 amps .. the 1-10 scale is for fine tuning.
                    On my 200 aead legends if I remember correctly I had to keep the fine tuning knob set to it's highest setting when using it for a generator, also you're not suppose to change welding modes while welding.
                    Important to use the right size welding lead if you want full power at a distance.
                    Changed due to 140 amp scale was wrong, it's 40 /100 scale
                      Scales would be as follows
                      40-130A range (each step is 10 Amps)
                      1 - 40A
                      2 - 50A
                      3 - 60A
                      4 - 70A
                      5 - 80A
                      6 - 90A
                      7 - 100A
                      8 - 110A
                      9 - 120A
                      10 - 130A
                      60-160A range (each step is 11.11 Amps)
                      1 - 60.0A
                      2 - 71.1A
                      3 - 82.2A
                      4 - 93.3A
                      5 - 104.4A
                      6 - 115.5A
                      7 - 126.6A
                      8 - 137.7A
                      9 - 148.8A
                      10- 160.0A
                      80-225A range (each step is 16.11 Amps)
                      1 - 80.0A
                      2 - 96.1A
                      3 - 112.2A
                      4 - 128.3A
                      5 - 144.4A
                      6 - 160.5A
                      7 - 176.6A
                      8 - 192.7A
                      9 - 208.8A
                      10 - 225.0A
                      100-250A range (each step is 16.66 Amps)
                      1 - 100A
                      2 - 116.6A
                      3 - 133.3A
                      4 - 150.0A
                      5 - 166.6A
                      6 - 183.3A
                      7 - 200.0A
                      8 - 216.6A
                      9 - 233.3A
                      10- 250.0A
                      Not having one in front of me this would only be the case if the knob only goes down to 1 and stops and up to 10 and stops. If it goes below 1 like to a 0 value or higher than 10, then I would need to recalculate the steps.
                        The knob on the right is the fine adjustment. It is a percentage of the middle knob. #1 = 10% # 5 = 50% #8 = 80% etc. of the middle knob range.
                        So if you set the middle knob at 100-250 amps, that gives you a 150 amp range. each number would be 10% of that range starting at 100.
                        If you set it to 40-100 then the range would be 60.
                        MM250
                        RCCS-14
                          thanks everyone for the help!!
