automotive welds
  • automotive welds
    Found these yesterday while looking at new trucks. Im assuming these were robotically done. Given the spatter I also figured they were FC of some sort. Do you agree? The main thing that surprised me was the undercut.Name:  6e99af195cc64a65858a3b766b586f79.jpg
Size:  30.7 KBName:  af09f8df679be79ff2aa4e64b53c04ca.jpg
    Thats not under cut, thats a plug weld and looks pretty normal for the application
      Sure looks undercut to me and not normal based on other welds on this truck and others on the lot. Its well out of the cut slot and that proabably is a defect as well. In the 2nd pic on the right end of the slot the weld wanders out of the slot which is clearly undercut.
        Looks pretty normal to me also. I worked at a car dealer body shop for 12 years.
          Undercut or out-of-the-slot; it's still probably 3x stronger than it needs to be. Don't try to eyeball how strong it needs to be; modern finite-element-analysis in design is unbelievably accurate, which is why modern vehicles & other structures are so much lighter & stronger than previous eyeballed ones. Besides: it's under warranty. If it fails, it'll be repaired or replaced.
          Walk softly & carry a BIG SIX ! ! !
          MM211 + SM100
            I doubt if its fluxcore but its robot for sure. I ran a robot doing HD parts for a while...Bob
            Bob Wright
              i am surprised to hear from you boys that this weld is ok and the norm, i looked at it closely, i would not let a weld like that out from my shop and i bet you guys would not either
                I'm not saying I approve of that weld. I'm saying the appearance of that weld is pretty common coming straight from the factory. Especially on bumper reinforcement.
                  Yes you are right because us welders care. But the factory doesn't. The sh !t that was going out of our shop was unreal but it passed inspection. I never would have let it go but it wasn't my call...Bob
                  Bob Wright
                    automotive welds have been ugly since the begining of time. a car or truck produced on a belt in 20 hours will look like that. im sure if you bought a hand built car the welds would be perfect and your bank account would be empty. probably over engineered and over welded anyway.
                      Kevin, That is not under cut, The weld is just not filled up to the top, Personally I would have flushed it out to the top, However I doubt that its going to fail.
                        The weld shown was from a frame rail reinforcement.
                          OK, the reason I thought it was FC was the spatter. I figured if it was MIG that would be absent.
                          Im unfamiliar w/ robotic welding but had the impression there was considerably more regularity than the welds I observed. Some looked like they had very good penetration and others appeared not to. Some were properly w/i the slot while other wandered (some considerably).
                            I would bet their welds are designed so not to use anymore wire than is necessary, they have a good idea of how long a vehicle is going to last before it's crushed and put on a boat and sent to China as scrap. Filling that weld to the top would be money out of their stock holders pockets.
                            Forgive my double posting, my computer is supposed to be delivered today. This machine is 2000 Gateway, it's as slow as a democrat on smoke break.
