Tig welding 5052 Aluminum. which filler ?
  • Tig welding 5052 Aluminum. which filler ?
    guys,
    we have a small project at work we will be tig welding which is made from .125" thick sheet metal, the alloy is 5052 aluminum.
    i searched the internet and see its safe to use 4043 or 5356 filler, which we already have in the shop.
    do you guys agree with this ?
    and is there anything special i should look out for when welding this type of aluminum ?
    thanks for any input, since i have never welded 5052 before.
    SyncrowaveŽ 200
    Lincoln AC/DC 225/125
    Lincoln Weld Pak 100 wire feed
    Either filler is good unless you are anodising it then go for 5356.
    4043 will be more ductile and less likely to crack but on the other hand 5356 is a stronger material but tends to crack if you don't cap the weld properly.
      5052 is also used a lot in marine applications. if it was going to be exposed to the elements i would use 5356. But as stated before either will work.
        thanks for the help guys.
        since it wont be getting anodized, i will go with the 4043 to stay away from the cracking...
        again, thanks much
        SyncrowaveŽ 200
          It would help to know what the project is. If it is something that is going to experience high temperatures, 4043 would probably be better. If it is something that needs maximum strength, 5356 would probably be better.
            5356 is actually more ductile, whereas 4043 may be a little softer, but will fatigue much faster than 5356 or 5183. I would never use 4043 on a seam that experiences vibration or variable loads.
            If you are welding 5052 sheet into a tank, you are much better of with the stronger filler. Personally I choose 5356 every time unless elevated service temps are experienced.
            Lately I have been using Maxal's 4943. Lightning fast for tig work, and bridges the gap in the strength area. Wets like no tomorrow.
            Miller Dynasty700DX
            3 ea. Miller Dynasty350DX
            Miller Dynasty200DX
            ThermalArc 400 GTSW
            MillerMatic350P
            MillerMatic200 with spoolgun
            MKCobraMig260
            Lincoln SP-170T
            Linde UCC305 (sold 2011)
            Hypertherm 1250
            Hypertherm 800
            PlasmaCam CNC cutter
            Fadal Toolroom CNC Mill
            SiberHegner CNC Mill
            2 ea. Bridgeport
            LeBlond 15" Lathe
            Haberle 18" Cold Saw
            Doringer 14" Cold Saw
              So there are some people using 4943. Shovelon have you been using it for just tig or mig also? Also what type of application? I've talked to my lws about bring some in for use on 6061-t4&6 plate for making race snowmobile engine mounts. From what I've talked to maxal it should be the cats a$$ after post weld tempering.
                i hope to one day have the knowledge you guys have....
                thanks for all the input
                SyncrowaveŽ 200
                  I haven't seen the 4943 on the AlcoTec Filler Alloy Chart, what alloys is it most compatable with? Going to have to do some research on this filler.
                  sigpic
                  Dynasty 200 DX
                  Millermatic 350P
                  30A Spoolgun
                  Lincoln Pro Mig 140
                  Hypertherm Powermax 30
                  14" Rage Evolution dry saw
                  40 ton press brake
                  Evenheat Heat treat oven
                  1x42 / 4x48 belt grinder
                    I have been using it with both mig and tig. I really like the tig rod. It flows like water and is fast. It is very strong too. I am hoping to phase out my 4043 tig rod soon. My LWS said they will stock it too.
                    As far as mig, it is watery in the flow characteristics, and lays a virtually smut free strong bead. The wire is shockingly brittle but drives nice in the 350p. I won't be switching from 5356 mig wire though as I have that down pat, smut and all.
                    Miller Dynasty700DX
                    Miller Dynasty200DX
                    ThermalArc 400 GTSW
                    MillerMatic350P
                    MKCobraMig260
                    Lincoln SP-170T
                    Hypertherm 1250
                    Hypertherm 800
                    2 ea. Bridgeport
                    LeBlond 15" Lathe
                      4943 is a Maxal product. You won't see it from anyone else. It is compatible with any alloy you would use 4043. Maxal's website has a lot of data for it's use.
                      http://www.marinelink.com/news/paten...ces350264.aspx
                      http://www.maxal.com/4943_datasheet.pdf
                      Miller Dynasty700DX
                      Miller Dynasty200DX
                      ThermalArc 400 GTSW
                      MillerMatic350P
                      MKCobraMig260
                      Lincoln SP-170T
                      Hypertherm 1250
                      Hypertherm 800
                      2 ea. Bridgeport
                      LeBlond 15" Lathe
                        I prefer alloy 4043 filler metal as it is better aluminum filler alloy. It was used for general purpose welding applications but now it can show significant variability in strength based on welding conditions as well as level of base metal dilution.
                          Thanks Shovelon, Ja
                          sigpic
                          Dynasty 200 DX
                          Millermatic 350P
                          30A Spoolgun
                          Lincoln Pro Mig 140
                          40 ton press brake
