How stupid can I actually be?
  • How stupid can I actually be?
    Last Fruday my Hypertherm plasma cutter showed up. Did a quick test drive on Saturday but had also bought an additional Hypertherm filter ($$$) and wanted to mount it before getting too carried away. Also only used in on 110 volts. But cut darn fine even on 110.
    So on the weekend I mount the secondary filter... hook it up to 220 and figure I'll give it a try. So it cuts a couple inches and the arc just stops? Pull the trigger again...cuts a couple inches and stops??? Look over at the front panel and air is good...no lights on that shouldn't be...no flashing lights. So I'm thinking is this additional filter screwing something up? Did I accedently knock a wire off when I had the cover off? Out with the manual (you know its serious if a guy is reading instructions) and looking at the troubleshooting section. Nothing there... a real head scratched.
    Then it hit me. Would probably work way better if I actually clamped the ground cable into the metal I was cutting! Back out to the shop...clamped on the ground and way she goes.
    The only thing more amazing than it would cut at all minus the clamp is me admitting I forgot to put it on.
    Going to make a sign for the cart that reads "Put Ground Clamp On Workpiece".
    Been there, done that! I couldn't figure out why my cutmaster kept cutting out one day. I could cut about 5" of 3/16" plate and then it quit. It was a headscratcher for sure. Glad you figured it out and didn't warranty the machine!
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
      It is really embarrassing when you call Hypertherm tech and they ask you about the ground.
      Miller Dynasty700DX
      3 ea. Miller Dynasty350DX
      Miller Dynasty200DX
      ThermalArc 400 GTSW
      MillerMatic350P
      MillerMatic200 with spoolgun
      MKCobraMig260
      Lincoln SP-170T
      Linde UCC305 (sold 2011)
      Hypertherm 1250
      Hypertherm 800
      PlasmaCam CNC cutter
      Fadal Toolroom CNC Mill
      SiberHegner CNC Mill
      2 ea. Bridgeport
      LeBlond 15" Lathe
      Haberle 18" Cold Saw
      Doringer 14" Cold Saw
        That's the story of my life welding or cutting sometimes I think my weld is going to look pretty good but when I pull the helmet up to look at it I'm not even on the crack I was trying to weld
          Sound a bit like the time I stomped all around the house grousing about not being able to find my glasses. Lucky for me someone pointed out that I was wearing them.
          Miller stuff:
          Dialarc 250 (1974)
          Syncrowave 250 (1992)
          Spot welder (Dayton badged)
            Ground clamp attached to work makes MIG weld, no clamp, no spark..., Turning shielding gas on helps with weld appearance, Making sure switch is in the MIG gun position rather than the spool gun position gives a much better arc and for longer, also leads to much less cussing and fussing.
            Just to make sure people weren't joshing me, I tried all of these....a couple of them multiple times to really make sure...
              Well it sounds like not too lonely a club at least. I'm also famous for marking a cut on the wrong side of the inch mark. So 5-1/4 becomes 4-3/4. Hey its 5 + a quarter...just the wrong way from the 5.
              But the best is I know a guy that was building a shop. It was going to be 40x60. Doing the foundation he didn't gave a 100 foot tape so borrowed one from the guy up the road. Came time to erect the walls and WTF...nothing is fitting. Ends up couple years before the hook end of the tape broke off so the guys cut off a foot and re-rivited the end on. He forgot to tell him when he borrowed it so the foundation ended up 39x59. Piss off was an understatement.
                This makes me remember to day I was welding on my work bench(before I had a welding table) with the part in the vice.It welded but seemed erratic.....hmmm.Got the part done and looked on the bench to see the ground clamp laying on a wrench,wrench touching a screw driver,screw driver laying against the vice......now I see the light DOH!
                  I'll have to give my kid credit. He was welding along in a community college class and noticed that his pant leg was on fire. Guess there was no setting on those fancy Miller welders that would prevent that.
                  Miller stuff:
                  Dialarc 250 (1974)
                    Yup, Happens to me too, The fact that it does cut some makes you assume that the ground is hooked up.
                      on my way home from work 10min ride. daughter calls we chat get home still chaten get in house unload everything (can't remember all) so after another 10min. chaten dang tell her got to go left cellphone at work she say's what repeat what I said (she said okkk kinda funny say's ok daddy)( put phone in shirt pocket) wife heard me says while heading for door where ya going I say left cellphone at work out I go before anything is said!!!!!! WELL get in truck and it HITS ME!!!! da_ _ I'm not going back in!!!!!! so go to basement for awhile wife comes down later smiling say's it comes and goes don't it I'LL pick some brouchures up tomorrow if ya want me to
                        that can happen with anything. Start of heating season is another issue. no heat. My response, is switch on ? Breaker ? OH ! Long quietness on phone. Wife must have hit it.
                          Have set my sweatshirt on fire while grinding titanium pieces.
                          I wear leathers to weld in but cotton to grind in - go figure.
                          A while ago, I had to make a metal shield for a friend's wood stove.
                          Used a piece of cardboard to make a pattern and traced the pattern on the metal.
                          Cut it out then realized that I had not flipped the pattern over before I traced it.
                          Of course the pattern was not symmetrical so I had to make another.
                          Think I would have learned from that but recently had to get a new side view mirror cut for my car. Made a pattern but again marked it on the wrong side. I now have a spare for the other side just in case.
                          Everytime I do something dumb like this I put $5 in a can on the work table to remind me.
                            Any alcohol involved?
                            I had to fix a hose reel at the house. I had fixed the aluminum crank on it in the past.
                            Made up my aluminum pieces for the reel, started the repair.
                            About 8 beers and 20 tungstens in. I finally took the magnet out.....
                            So you can't weld Aluminum to steel, hmmm....
                              A week ago I got a new Tig welder. It had issues with the torch and foot pedal, and I was so distracted that I left the full 125' Argon bottle with the valve back seated. Two days later I found it empty. At least I now know what refills cost at my LWS.
