welding aluminum with the spoolmate 100
  • jhamm75
    started a topic welding aluminum with the spoolmate 100
    I recently purchased a Millermatic 211, and also got the spoolmate 100 spool gun to try some aluminum welding. The welder works awesome on the steel projects i have done, but i cant seem to get the spoolgun to work like i want. I have a hard time getting a puddle to form, the wire seems to burn up before it hits the metal. I have tried the settings recommened on the machine, and tried extreme settings but it doesnt seem to change much. When i leave the wire out about 3/4", it seems to just dissapear when i pull the trigger. I used .030 5356 wire at first, but switched to .030 4043, which seems to be better in that i can sort of leave a bead, but still cant see a puddle or wire, just a glow. I am using 100 % argon gas. I am trying to weld 1/8" thick aluminum sheetmetals and sqare tubing. Any information is appreciated. Thanks.
  • mikeswelding
    I've had the Spoolmate 100 for a few years now and use it with the Passport Plus. I have always had good results, but find that the factory recommended settings are not always the best, so do some experimenting. Also, are you prepping the aluminum with a stainless steel brush and cleaning solution? That will make a big difference in the puddle. Also be sure to always "push" the weld, as mentioned before.
  • strictlycarved
    Use 035 instead and up your speed if your using the 30
  • Broccoli1
    I didn't have any problems with the tips provided.
    AL can be frustrating - everything needs to be set up precisely, any minor change has a major effect😜
    Push while welding al.
    Stick out
    Contact tip to work distance- the distance between the end of the wire and the work
    Check the drive roll tension on the gun
    Once arc is established you gotta boogety boogety as it is a lot faster than welding steel.
    The bottle of Argon could be contaminated
  • Kpack
    460 Ipm on 211 auto set is tops I have a older 140 that will do 600 Ipm a little bit of difference the 140 has got plenty wire speed but not enough heat for aluminium millermatic 252 700 Ipm tops
  • jhamm75
    Thanks for the replies everyone. Ill do a search on the spoolgun.
  • Kpack
    Wire feed speed check your manual what kind of wire speed they have on the newer units not as fast as they used to be don't ask me how I know.
  • MMW
    It sounds like your wire feed is not high/fast enough. Also there is issues with the tips.
  • cruizer
    This has been posted more than few times, try a search on the Spoolmate. It all comes down to a tip issue for this model.
  • Guest's Avatar
    Guest replied
    Not too familiar with that spoolmate but on a spoolmate 30 I think I ALWAYS start out with my voltage on 5 or so and keep my finger on the wire/amperage adjustment and start out with TOO much wire and then back it down. Also, make sure you are using 100% argon....NO C25....I almost always push the puddle with a spoolgun
  • Packers To Super Bowl !!
    Try turning the thickness to 3/8, & wfs to 100.
