Fittings on Oxygen Supply Line
  • Fittings on Oxygen Supply Line
    Can galvanized fittings be used in an oxygen supply line? The gauges on my oxygen tank are too low for me to read and I want to arrange them so they face up rather than forward. Brass fittings cost 3 to 4 times more than galvanized.
    Twist the regulator and position it easier to see before you tighten it.
      All fittings used in fuel gas and oxygen lines should be of a non-sparking material...
        Follow this advice. Three to four times the cost in this instance is only a couple dollars. Brass is also a soft material so it seals better & less chance of ruining the regulator body.
        MM250
        RCCS-14
          brass
          as you have been told and i agree. use only brass.
          the reason is safty. any spart generated by anythink like steel could cause harm,to you.
          yes they cost more,or do you what to be hurt or injured or worse?
          do what is safe.
            I second that... makes sense.
              Be sure you get fittings rated at the proper pressure if you're also modifying the high pressure gauge.
              I don't know what the specs are for oxygen service, but I imagine the brass is used for corrosion resistance. I don't know how well the galvanized will hold up. It may quickly corrode all the zinc, and then start attacking the steel.
              Dynasty200DX w/coolmate1
              MM210
              MM Vintage
              Lincoln AC225
              Victor O/A, Smith AW1A
              Cutmaster 81
              IR 2475N7.5FP
              Evolution Rage3
              Jancy USA101
              9" South Bend
              AEAD-200LE
