Pulsed MIG v. TIG
  • Pulsed MIG v. TIG
    I have a potential job that is a water tank,
    The longest weld is 17" in length. Shortest weld is 7".
    95" of weld length in total.
    Material is 3003 AL .125" thick.
    This tank will be hidden too. And possibly powder coated.
    From A speed standpoint MIG will be much faster IMO. TIG will produce a better
    looking weld.
    My power sources are
    Synchrowave 250
    Invision 456 with Optima Pulser pendant
    With this all said what process would you guys use?
    Thanks guys.
    Tom
    My personal opinion, pulse is for people that can't weld correctly and want to cheat in order to make it look good.
      Pulsed MIG v. TIG
      Not sure I understand?
      If u can't weld and can make ur weld look good with pulse then if u can weld u can make a weld look great.
      But it's about Quality 1st. & foremost then speed, need to make profit or u wolnt be in business long. As for me I weld stick, O/A, mig, tig. Personally tig is my last choice just takes to long but sometimes it's the best or only choice.
      Likewise pulse is not always the best choice but it has its qualities also, u get great penetration with less heat & distortion. Also it is very fast. If its hidden & painted my choice is pulse mig. Take ur girl out for dinner with extra profit.
        Most tank shops have gone from low speed tig to high speed pulse. Identical welds, identical penetration, actually better with the pulse Mig. I'm quite certain the welders know how to weld procedure pulse.
          I am all about time. Looks are a factor but when the appearance is close to identical then pulse wins.
          Thanks guys!
          Tom
            As for that comment, when you think about it for a minute it makes absolutely no sense as pointed out previously.
            Now for the question at hand. I fab hydraulic tanks out of the same material and the same thickness. The name of the game is obviously the right combination between speed and quality (looks). With the pulsed mig, when done properly, you can get that "stack of dimes look" and still double your speed over TIG. Pulsed MIG is definately the way to go. IMO
            JIM
            Millermatic 350P Aluma Pro
            Maxstar 150 STL
            Trailblazer 302
            Suitecase 12RC
            Extreme 12VS
            Extreme 8VS
            Spoolmatic 30A
            Miller HF251D-1
            Passport Plus
            Spoolmate 100
            Hypertherm Powermax 45 and 85
            Dake 75 ton H-Frame Press
            JD Squared Model 32 Bender
            Miller Digital Elite
              Thanks Jim!
                Pulsed MIG v. TIG
                I'm rebuilding underground Reamers for local company. Welding 4130 alloy and a lot of 1" & 1-1/2 thick metal. I switched to pulse mig with dual metal wire. Very happy with results, much faster, in some areas cut my time by at least 25%.
                Great results, welds holding up as good or better than mig,
                Plus I don't need to switch wire as often, can just turn down and weld 1/8" with .045 wire better than straight mig. Just a no brainer for me, definitely increased my profit.
                  I'd probably tig weld it only because if I tig it theres almost no need to check it for leaks and we are only talking about 96" of weld.
                  On The other hand, I dont have a pulsed mig set up and dont know how good they work.
                  I have a push/ Pull set up which is a Cabra/Mig 260 which is a good set up for 1/4" and up, so so for 3/16 .
                    Bunch of cheaters
                    http://www.millerwelds.com/resources...&submit=Search
                    Ed Conley
                    MM252
                    MM211
                    Passport Plus w/Spool Gun
                    TA185
                    Miller 125c Plasma 120v
                    O/A set
                    SO 2020 Bender
                    You can call me Bacchus
                      Originally posted by Broccoli1 View Post
                      Just reading the first article from the link you shared. It clearly states the welders are lame and the company hires people who don't know how to control their heat and blow thru's I've several times welded .020 aluminum with not one issue. The idea behind this pulse welding is so that the employer can hire people that don't know much about welding thin metals and pay a low wage. The metal in that article was no thinner than .080. If one can't weld that crap and not have a blowout maybe they should look for a new career. Jmo
                      I was only stating my opinion not bashing the OP. Sorry to offend any of you guys that was not my intent.
                        You just gotta laugh when you get a "Professional" welder on here that has to give his opinion on something he knows nothing about.
                        JIM
                        Maxstar 150 STL
                        Trailblazer 302
                        Suitecase 12RC
                        Extreme 12VS
                        Extreme 8VS
                        Spoolmatic 30A
                        Miller HF251D-1
                        Passport Plus
                        Spoolmate 100
