Preheating Prior To Welding Alloy Steel Pipe.
  • Preheating Prior To Welding Alloy Steel Pipe.
    Welding Alloy Steel Pipes Using GTAW 1/2" Pipes
    What is most convenient way to Preheat.?
    Which Equipments should be used to Measure Temperature.
    Please do the needful......
    Oxy act and a temp stick
      If its big pipe you also might want to consider one of those weed burners hooked up to a propane tank provided your just trying to take the chill out of the pipe.
        I use propane for Pre heat due to cost of acetylene. H/D weed burner for the big stuff or propane Rosebud tip on torch for smaller things.
        Use Laser Thermometer to read temp.
