Soda can welding....
  • Soda can welding....
    I was tinkering with this last night and would like to some more. I was able to get the cans joined and some filler in there but the problem was contamination. What's the best way to cleann the cans? I used coke zero cans and a wire wheel to remove the coating. I think a chemical would do it better? Was very difficult to establish a "clean" puddle. Dave
    There are a couple youtube videos you can watch.
      The inside of the pop cans are coated also, its very had to get a contamination free weld with pop cans
        You'll have better luck with beer cans. Once you empty enough of them you won't care anymore!
        Miller Syncrowave 200
        Homemade Water Cooler
        130XP MIG
        Spectrum 375
        60 year old Logan Lathe
        Select Machine and Tool Mill
          Probably best off with the brush. The chemical you would need to get that coating off would be pretty "heavy duty" and probably hard to find. Think about how corrosive coke is. At our fire department we use it to clean blood and oil off of the roads after a car accident, works better than you think
          Frank
            Your asking in the wrong place. You need to ask the guy at the flea market with the special aluminum rods.
            MM250
            RCCS-14
              I welded some DP cans, the coating inside causes a problem, if you can get a clean drop of weld started, you should be able to get around it.
              http://mob854.photobucket.com/albums...dpopcan003.jpg
                Pop Can welding
                Hi You can weld two pop cans together with TIG. Turn down your amps as low as you can and use pure argon. weld them bottom to bottom. Clean with a new wire brush and only use it for aluminum. Clean with acetone. Post the picks on here when your finished. Visit youtube or visit weldingtipsandtricks.com Jody is a great goto with questions and has a ton of videos.
                  At $ .10 a peice I find that its way easier to throw them out than to weld them.
                    I used a scotchbrite wheel and then acetone, which worked great.
                    I also tried a wire wheel and it embedded paint deep into the surface.
                    Miller Dynasty700DX
                    3 ea. Miller Dynasty350DX
                    Miller Dynasty200DX
                    ThermalArc 400 GTSW
                    MillerMatic350P
                    MillerMatic200 with spoolgun
                    MKCobraMig260
                    Lincoln SP-170T
                    Linde UCC305 (sold 2011)
                    Hypertherm 1250
                    Hypertherm 800
                    PlasmaCam CNC cutter
                    Fadal Toolroom CNC Mill
                    SiberHegner CNC Mill
                    2 ea. Bridgeport
                    LeBlond 15" Lathe
                    Haberle 18" Cold Saw
                    Doringer 14" Cold Saw
                      thx attempt two tomorrow
