Miller XMT 304 CC
  • Miller XMT 304 CC
    I am new to welding. I acquired a Millermatic 175 and can do basic mig.
    I have a Miller XMT 304 cc. Not a cc/cv.
    I am hooking it to a 220 line with a 50 amp breaker. I assume this is adaquate for basic stick welding.
    That is my question. Will the 50 circuit be ok? I do not plan on using it at max.
    Any thoughts or ideas are welcome.
    According to the owner's manual, it requires 47 amps. A 50 amp breaker ought to be just fine.
      Setting on the Miller 304 cc
      Ok. Now what are the basic settings for the Miller XMT 304 CC. I am going to weld on a front bucket on a backhoe. Repair work. I split the corner and need to repair.
      I have not used the 304 and need to determine the proper settings.
        I have never used one, but there should be some starting settings listed in the manual.
          Make sure when you power it up ( Wiring the plug ) When hooking it up to single phase you do not use the red wire.
          Set the machine on panel verses remote ( Remote is for changing your amps with a remote that you dont need.
          And set it to arc weld and you should be fine.
            I would use this online weld calculator to find a good starting point for your weld settings.
