Safety Question - sparks/wood ceiling ?
  • Safety Question - sparks/wood ceiling ?
    Can anyone address a concern I have on safety.
    I'm putting fire proof welding curtains up in garage,
    cement floor, cement outside wall.
    My concern is the ceiling - typical peaked plywood roof with
    a few 2x4 trusses 10 feet high.
    Should I put fire proofing up there as well ?
    Using a passport plus.
    Please advise,
    Thanks, Stu
    As long as your welding at shoulder height or lower I don't see problem. Gas shielded solid wire?
    A lot of it is just keeping your SA up.
      Using the CO2 internal bottle.
      May get a bigger bottle in a while - see how it goes.
      Just doing tack welds for armatures.
      Thanks, Stu
        On the other hand, if the shop already is torn apart, etc, why not add it now if you can?
          I would say get a couple of fire extinguishers . If gasoline is stored there invest in a safety can instead of plastic containers.
          I don't think your gonna have sparks going up seven feet above your welding table. If you are concerned hang a blanket above the table.
            Fire extinguishers are a must no matter what. My shop is pretty good sized - 40 X 60 with 14' ceiling, and I dont weld or cut on anything before leaving. Even then I turn the lights off and look around in the dark to make sure theres nothing smoldering. Another good reason to have a clean shop
              No gas or flammables in garage,
              just wondering about sparks going up to ceiling.
              Two new fire extinguishers in place.
              Thanks, Stu
                Yeah guess your right - I'll sleep better.
                Thanks, Stu
                  I would not worry with ceilings that high. I frequently weld in an area with 8' ceilings and there is zero spatter trails on it.
                    We try to go back and check for fire/problems three to four hours after the end of operations for the day. We have found a wall on fire and various things smouldering. Guess I need to clean up the shop. Also cooling pumps in trouble(not welding equipment) and things left on that we were told had been shut down. My experience is that a few hours will give a problem time to get going enough to be noticeable.-Meltedmetal
                      Grinders/grinding are more dangerous than welding
                        That's why I tig only in the garage. No sparks.
                        Im continually afraid of that in my 2 car attached garage. Mig and Stick are outside only items for me.
                          I've set clothing on fire with grinders, never with welding.
                          I would put Sheetrock up, it's cheap.
                            I've started fire from nothing but heat, not to mention sparks.
                            You could hardly be too safe.
                            Pretty hard to beat having a legitimate insurance policy in force as well.
                            Not as an excuse to be careless, but rather because when you are only one person, things can happen.
