Coolmate 3.5
  • Coolmate 3.5
    I'm looking to add a cooler to my dynasty200 and was looking to go ahead with the 3.5 with plans on getting a dynasty350 at some point later. Is the 3.5 compatible with the dynasty200?
    Ya good thinking
      Coolmate 3.5
      It won't fit in the Dynasty 200 runner cart. It's a cooler it will cool the torch! Same size fittings as the cool mate for the 200
        I'm going to build a cart as I've Ben using a harbor freight cart that I use for a mig. I just haven't seen any info of anyone using the 200 with the 3.5 so I just wanted to be sure before purchasing one. Thanks
          Stupid question but will a cool mate 3 not cool enought on a dynasty 350 ???
            Coolmate 3.5
            I would think it would, don't know if it will bolt up to the 350 or 700, it's rated up to 600 amps
              Coolmate 3.5
              Cool mate 3.5 is rated up to 700 amps
                I have one in my Sync 250. It may be overkill for 310A but the torch never gets hot. Thanks Miller engineers!
                  Ya that's why I say a coolmate 3 is fine plus it's around 300$ cheaper and for what he is running or going to run it will still work plus if your going to build your own cart fitting it is no problem I would look at the coolmate 3 if I were you just my 2 cents
