welds failing on intake plenum need help/advice
  • welds failing on intake plenum need help/advice
    I built an intake plenum for a 4 cylinder engine. I used .090" h3003 aluminum sheet and 4043 filler rod. I put x creases in the panels to stiffen them. I used 1/8" pure tungsten and 1/16" filler rod. This is a turbocharged application and it sees quite a bit of pressure. After I fabricated it I built a pressure tester. cycling the pressure to 30 psi a couple of times results in cracks in the long seams. I initially drilled small holes at each end of the crack, ground the weld down to base material and re-welded. cycling after the repairs results in cracks in other areas. I have done a couple of plenums prior to this using heavier 6061 t4 plate and 4043 rod with no issues. Have I chosen the wrong base material or too thin? I am not a professional welder but I have some experience and from what I can see I have good penetration. I'm using a syncrowave 180. I am at the point of scrapping the assembly and starting over. I don't have a way to post pics at this point but really I would like to know about the base material and my choice of filler. Thanks.
    It's probably not your welds, it's your design. Thin metal, unsupported, will flex and fatigue at the joints. You need to brace it up or redesign to eliminate large flat surfaces, I suppose.
    CG
    Old Miller Swinger 180 Buzzbox
    Miller Diversion 165
    1945 Craftsman Atlas Lathe
    Smithy Lathe/Mill
      It would help if you would post some pictures
      Nick
      Miller 252 Mig
      Miller Cricket XL
      Millermatic 150 Mig
      Miller Syncrowave 200 Tig
      2-O/A outfits
      Jet Lathe and Mill
      Jet 7x12 horz/vert band saw
      DeWalt Multi Cutter metal saw
      Century 50 Amp Plasma Cutter
      Propane Forge
      60" X 60" router/plasma table
        well 4043 is used when joining other alloys to 3003
        AL 1100 filler is used when welding 3003 series aluminum's to other 3003 series aluminum's
        try the right filler for the material and if your design is good the problem should go away with the cracking
          Thanks for the replies. I think the material is just too thin for the design. I'm going to get some 6061 .187" flat sheet and start over. I did try making up some reinforcing angles and welding them across the seams and it did seem to keep it from cracking in those areas. I THINK if I applied them all over it might hold up. This is for my dd so not going to chance it.
            What kind of car is it?
              .090 is WAY to thin for that
              Miller 30-A Spoolgun
              Miller WC-115-A
              Miller Spectrum 300
                Wrong filler, material to thin, possible design problem.
                I built supercharger manifolds with 6061 .125" 4043 filler with no problems.
                and wp2025 weldcraft torch
                Miller 125c plasma cutter
                  Yes, .125 or thicker should be ok.
                  Also look at your weld joint design, try to steer away from corner to corner welds and maybe look at using a lap weld design.
                  If not, can you get access to weld internally as well as externally?
                  I'd use 4043 filler unless the weldment needs to to anodised in which case 5356 is the requirement there.
                  Regards Andrew from Oz.
                  We are tig welders, gravity doesn't worry us.
                  Miller Dynasty 350 Tig.
                  OTC AVP300 AC/DC 300 amp hybrid wave Tig. (now retired)
                  Kemppi MLS 2300 230amp AC/DC Tig for home with all the bells and whistles.
                    Its a 1987 Plymouth Horizon.
                    I can't weld on the inside unfortunately. I'm going to the metal supply today and see what they have available in the drops bins in 6061. I tried the .090 because I could shear and bend it with the equipment I have. I'll try and post pics as I go along this time. Thanks for the replies and info!
