Outdoor Ratings On Migs?
  • Outdoor Ratings On Migs?
    Hi, I'm wondering if someone would explain the outdoor standards or codes used on some mig welders eg caddy says p23 TA181i p23s What is the Passport? or doe's miller have there own system? thanks for any info Joe.
    I don't understand what your asking?
    MM250
    RCCS-14
      Sorry/ I will try to explain. I was reading the literature and it states the waterproof ratings for outdoor use an I wondered if some models are rated higher like p23 means suitable for outdoor use. Thanks Joe,
        I found this
        http://www.ezscreen.com/ip_ratings.htm
        I don't know the rating of the Passport but with the type of enclosure it has I would bet it is equal to the Fabricator series from Thermal Arc
        Ed Conley
        MM252
        MM211
        Passport Plus w/Spool Gun
        TA185
        Miller 125c Plasma 120v
        O/A set
        SO 2020 Bender
        You can call me Bacchus
          Thanks' Ed,
