simple Tig question
  • simple Tig question
    Hey how's it going I have a simple question that came up between me and a friend. Dose a foot pedal give you the same amperage control on lift start as it would on Hf-start on a XMT machine.
    A xmt doesn't have high frequency unless you've added a external high frequency box such as a hf-251. The amperage would be the same.
    Dynasty 200DX "Blue Lightning"
    Bernard 3500ss water-cooler
    Rockwell vertical mill
    Beverly Shear B-3
    Beverly Shear JR
    Home-made English wheel
    Milwaukee Porta-band
    " Sawz-all
    Tennsmith 36" stomp shear
    Fixer upper 1968 Redface Lincoln sa200
    Powcon 300st
      simple Tig question
      The question is about amperage control I am aware there is no Hf on this machine
        I interpreted the question the same way Showdog75 did. It seemed as if you were comparing the foot control in HF and LA on an XMT.
        The foot control should function the same on LA or HF on any electric machine. I mainly use Miller machines so I can't say much as far as lincoln machines go, but I am sure they work the same.
        If the XMT has auto remote sense, it would for sure be the same.
          So essentially you have asked 'Is amperage control the same on this machine if I use a feature that is has, as well as if I use a feature that it does not have?'
            simple Tig question
            Ok maybe I worded that poorly. Dose the foot pedal amperage control function properly in lift start Tig welding. High freq. is only mentioned as reference. Or better yet. Can you still use a foot pedal if you don't have HF.
              Foot control controls amps, regardless of how you start.
              CG
              Old Miller Swinger 180 Buzzbox
              Miller Diversion 165
              1945 Craftsman Atlas Lathe
              Smithy Lathe/Mill
                simple Tig question
                Thanks that's what I was looking for CG
