x-treme 12 vs with lincoln 400 sae
  • boomertoo2
    started a topic x-treme 12 vs with lincoln 400 sae
    Hi all can I run x-treme 12 vs with lincoln 400 sae
    It says on the 400 sae tag that its variable ocv .
    I just got the 12 vs and a bottle of trimix
    I need to weld quite a bit of stainless and dont want to kill the 12 vs
    if the welder is not compatable.
    Steve
  • boomertoo2
    Originally posted by cruizer View Post
    I have ZERO idea on which SAE400 you have.
    A code # would be handy for me to pull up the correct spec's
    Mine is an gasoline engine driven shield arc sae-400
    serial a-701394
    code 7175
    There is no model number that I can find
    I would appreciate any info and year built you can find
  • cruizer
    Originally posted by cws612 View Post
    my apologies, i assumed boomertoo was referring to a engine/generator sae 400. i never knew them to be other than stick machines (cc). i am not questioning you just your response. if the sae 400 is a variable voltage stick machine, should the 12vs feeder control be set on cc? thanks, tom.
    Code# so we can be on the same page, there is about 6 different SAE400's
  • cws612
  • cruizer
    cruizer, i am confused, if the sae 400 is a variable voltage machine wouldn't you run the 12vs on constant current setting? (? on your post #9.) thanks tom.
  • cws612
    CV mode
    And no reason to change polarity unless your running fluxcore
  • boomertoo2
    Thanks much
  • cruizer
    CV mode
  • boomertoo2
    The 12RC will NOT work on the Lincoln cause there is NO 24Vac to run it.
    OCV, merely means Open Circuit Voltage, zero to do with Constant Voltage which unless you have a CV module on the SAE, it's not there
    If the SAE 400 is variable voltage should I use the CC or CV setting on the 12-VS ?
    Also is it ok to reverse polarity when using the 12-VS ?
  • cruizer
    Every machine will run the VS suitcase, but only those having 24Vac will run a RC
  • pressurewelder
    Thanks cruiser. I run it (12rc) with a tb302 and it seems to run great. Iam I doing things right? And why wouldn't a 12k machine be able to run it? It looks more and more the 350pp is the way to go it will run the vs and rc
  • cruizer
  • cws612
    Originally posted by pressurewelder View Post
    I kinda have the same problem I have a 12rc suitcase and was wondering if I could use it with a vantage 300 or 400 or do I have to use a ln-25?
    12rc requires a constant voltage setting on the machine its hooked to i believe. however the ln-25 should work no prob.
  • cws612
    Steve
    12vs should be fine with sae400
  • pressurewelder
