Cruizer
  • Cruizer
    Hey Jeff I was just wondering what kind of meter your using to measure hz. I have a clamp on Greenlee 950 (if that helps any). I can only get a hertz reading if I clamp the meter around one wire on a cord I rigged up and plug in my rod oven. I tried plugging the leads into the outlets but don't get a reading that makes sense.
    Nope doesn't make sense, Stick the probes into a receptacle, What your wanting is AC frequency.
      I have an Ideal meter that reads Hz, but it goes crazy on a generator that isn't loaded.
      So, I put a cord on a panel mount Freq meter and just plug it in.
      Jeff
        frequency
        just a quick refresher please. what is the proper frequency for proper welder rpm for a welder/generator. thanks, i know you have mentioned this before just don't remember what thread.
          62.5 hz small gasser, like Lincoln 305, Miller 302
          60.5 - 61 hz for a Lincoln Classic, Vantage, Miller pipepro350
          61 - 62 hz for Miller pipepro 304, Pro300
            My poor mans frequency meter method is to use my Kill-a-watt meter.
            Drawback is that it only good for 120 VAC.
