Wasting Wire
  • Wasting Wire
    When changing spools (I.e. GMAW to FCAW) will it damage the liner to pull the wire back into the spool? In other words is it harmful for the wire to go the other way?
    Obviously I'd release the rollers first.
    I don't want to cut off and throw away 10 feet or so of wire every time I change wire type if I don't have to.
    Miller 211 MVP
    Hobart StickMate LX 235
    Lincoln AC 225
    CutMaster 42
    Just nip off the ball on the end first so it goes through nice, flip the rollers and rewind.
      Sweet! Thank you.
      Miller 211 MVP
      Lincoln AC 225
      CutMaster 42
        Do it all the time just as walker described.
        Syncrowave 180 SD
        *HF-251D-1
        *WC-1S & Spoolmatic 1
        PakMaster 100XL
        Marquette "Star Jet" 21-110
          Yup, eating that much wire would be pointless
            You might even be able to TIG weld the last 10' of wire off the empty roll onto the leader of the new roll. That might be a bit extreme though.
              LOL!!
              Reminds me of welding school when I was an apprentice. They would have us TIG weld all the TIG rod stubs together at the end of each day. Then you'd have a job on your hands trying to roll the rod down with your left hand with all these bumps and bends in the rod.
                Originally posted by Matrix View Post
                LOL!!
                That would certainly teach you that good fitting and welding is a must!
                  LOL!!
                  Ha ha that was the way my teacher did it. He didn't have us do it at the end of class but he liked to see you stick the short end on a new piece. Then we'd clean up the stick booths and there would be half a box in half used rod on the floor lol
