Xmt350cc/cv mild steel mig wire
  • Xmt350cc/cv mild steel mig wire
    Hello everybody out there!I am now experimenting with mild steel mig welding on my xmt350cc/cv.I have 1.2mm wire and using argon shield(argon+co2+O2).Its okay with 5mm upwards materials.I intend to do some fabrication involving 0,8mmm up to 2mm in thickness.I was thinking of getting 0,6mm wire?Can this be the right size?
    I have a 24 volt 70 series wire feeder.
    Miller MIG calculator
    Powerweld,
    Miller's mig calculator indicates 0,8mm wire for the steel thickness range you've specified, however, I don't see why .6mm wire shouldn't work... you'll just run more wire....here's a link to the calculator which also recommends gas and wire feed speed (if I figured right approximately 5.6-8.6M/min):
    http://www.millerwelds.com/resources...calculator.php
    The calculator is also available as a download if you have a smartphone. Although folks have preferences, this should get you close at least.
    Tim
    ____________________________________________
    Miller Spectrum 625 Plasma
    Miller XMT 350 CC/CV Inverter w/optional gas valve
    Miller Suitcase Extreme 12RC
    Miller Digital Elite
    Miller RFCS-14HD pedal
    Smith HM2051A-580 Flowmeter
    Bernard Q300 MIG Gun
    Weldcraft WP26FV-12R Air Cooled Torch
