problem with distributor on 1970 Miller big 40 please help.
  • problem with distributor on 1970 Miller big 40 please help.
    I pulled the distributor it out of my 1970 Miller big 40 with a Continental F 163 motor in it. I installed the new distributor , but now when cranking over the motor the rotor isn't spinning. It spins for a slight second then stops or if I pulled the distributor out slightly it will spin properly. Then when I tighten the distributor down again the rotor stop spinning again. Not sure what the problem is if you have any information I'd appreciate the help thanks
    That sure doesn't sound right. I am not too familiar with the Continental but have worked on a engine or two. Does the distributer look to be the same, as in length from mounting pad to the gear? I am assuming these are gear driven off the cam and it sounds like the gear is not enguaging correcty. I would compare old alongside new for a minute so see if any differances. On some enginse you could also acctually install (pin) the drive gear upside down on the shaft.
    Campbell Hausfeld 110V MIG
    Jo Ann Fabrics Hot Glue Gun
      Fits into a knotch on your oil pump shaft, perhaps the knotch is busted off
        No it fits into the knotch its not broke on the oil pump and oil pump is spinning. I can see the key spinning when i crank the motor by hand.
          The dist shaft is one piece, sooooo, if the pump shaft is spinning, so is the dist shaft. Dist shaft broken?
            A few questions.
            1) Why did you replace the distributor in the first place?
            2) Have you had the oil pump out lately?
            3) Does the engine build oil pressure when cranking?
            Possibly a sheared driven gear to oil pump shaft pin?
            Syncrowave 180 SD
            *HF-251D-1
            *WC-1S & Spoolmatic 1
            PakMaster 100XL
            Marquette "Star Jet" 21-110
            http://www.millerwelds.com/images/sm...rolleyes.png?2
              Okay yes the shaft is 1 piece go straight to the oil pump to the distributor. the distributor is brand new so I don't think the shaft is broken. it spins perfectly fine if I pull the distributor out of the manifold a little bit. once I tighten it down it stop spinning. I don't think it had a spacer didn't see 1 when I pulled the old 1. Pull distributor because the housing was cracked. And yes I have had the oil pump out recently. Can see it's a little pressure is building when starting welder gauges on the side of welder will check that tomorrow . Also don't think you're is shredded because can see oil pump shaft spinning when cranking over the motor if I look down the distributor hole.
                I talked to both you and cruisers hey couple weeks ago about trying to get the distributor out of the intake manifold. You told me to drop the oil pump and drive it out from the bottom. And cruiser told me to yard the head which I didn't know what that meant at first. so I drop the oil pump and tried driving it out gonna get it. So I pulled the head distributor stayed in the head. Wind it up have to drive it out of the head but finally got it put it all back together and this is where I'm at.
                  There is a pin that locks the drive cam gear from the oil pump onto the oil pump shaft. Thats what Duane was talking about. And thats the only part that would stop the dist shaft from spinning.
                    To tight.
                    I would bet something is wrong when it went back together, and snapped the pin in the drive, the reason it turns when the dist is loose there is little resitance, Once tight the restiance goes up. Do this, remove the dist, use a piece of rod, grind down the rod to fit into the oil pump, Insert, now turn the motor over by hand while holding the rod with a pliers, see if the rod turns, bet it wont.
                    Kevin
                    Lincoln ranger 305g x2
                    Ln25
                    Miller spectrum 625
                    Miller 30a spoolgun
                    Wc115a
                    Lincoln 210mp
                    F550 imt service truck
                      Or just use the old distributor shaft
                        Yup....
                        . I assumed they took the old dist for a core, if you still have it you can use the old. Nice thing about a rod is you can see it engage.
                        Kevin
                        Ln25
                        Miller spectrum 625
                        Miller 30a spoolgun
                        Wc115a
                        Lincoln 210mp
                          What do you mean rod like a piece of round stock that's all the distributor shaft is a piece of round stock with a slit on both ends once it's over the oil pump shaft then runs up to the distributor
                            Yup
                            Yup you got it
                            Ln25
                            Miller spectrum 625
                            Miller 30a spoolgun
                            Wc115a
                            Lincoln 210mp
