another old Airco needs ID
  • another old Airco needs ID
    Hi, My first post here. I have an Airco with a Kohler motor. It all worked last time I used it but when I fired up the motor recently I got no output. I plugged in a trouble light which lit and then died much like a capacitor discharging. Now it won't do that and I read 10V AC at the generator outlet. The only number I can find on the welder is W537125 and I saw somewhere it might be a style W1. I checked the brushes and cleaned the tarnish off the slip ring so far.
    I have attached a couple of pics to help ID it. I would appreciate suggestions of what to check or help getting a manual for it.
    Thanks, Joseph
    Looks like my Roughneck.
    http://www.millerwelds.com/om/o419f_mil.pdf
    From Millers cross reference list
    Airco Miller
    1.8ADG-AMEL-A ROUGHNECK
    1.8ADG-AMPL-A ROUGHNECK
      [QUOTE=big mike;294061]Looks like my Roughneck.
      Sure does look like it. On mine the throttle arrangement doesn't have the labels for Power & Weld and some of the internal electronics look different. I think I might have an older model than the manual shows. Thanks, I'll do some more investigation on the roughneck line but the manual you have helps a lot.
      Joseph
        Hi Joseph, hopefully this link can help you out with the manual instructions http://www.millerwelds.com/om/o340d_mil.pdf. It contains a detailed description of every component and the problem with their causes that can disrupt their normal functioning.
          I just checked back after all this time. Thanks for the URL.
          Joseph
